Https setup in graylog 3.0
I am setting up https in graylog with CA signed(not self singed) after that i am facing the issue and nothing loads in graylog UI.
Please find my server.log:
is_master = true
password_secret = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
root_password_sha2 = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
data_dir = /graylog/graylog-server
http_bind_address = xxxxxxxxxxxxxxxxxx:9000
http_enable_tls = true
http_tls_cert_file = /graylog/graylog-server/certificates/xxxxxxxxxxxxxxxxxxxxxxx.pem
http_tls_key_file = /graylog/graylog-server/certificates/xxxxxxxxxxxxxxxxxxxxxx_pk8.pem
http_tls_key_password = changeit
elasticsearch_hosts = http://127.0.0.1:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = /graylog/graylog-server/journal
I am formatted the key as PKCS#8.pem format and certificate is .pem.
Please let me know if it is really necessary to add the certificate in cacerts?
-Arif
if you have used your own CA. Did you add this CA to the java keystore that Graylog is able to connect to itself and verify the certificate?
Did you checked the Graylog server.log?
I checked the server.log but did not find anything relevant.
I did not added them in cacert. I will try that now.
I do not have any logs for https but when i set the value of “http_tls_key_password” graylog does not start itself.
2019-03-20T02:32:01.422-04:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:148) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) [graylog.jar:?]
Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
Caused by: java.io.IOException: overrun, bytes = 2351
at javax.crypto.EncryptedPrivateKeyInfo.(EncryptedPrivateKeyInfo.java:92) ~[?:1.8.0_201]
at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:69) ~[graylog.jar:?]
at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:98) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:342) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:168) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:142) ~[graylog.jar:?]
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_201]
does your certificate need a password?
I have added my certificate in cacert.jks still no luck.
I have setup the https and everything is working except when i click system–>node–>node ID.
Please find the screenshot…
and when i click node below error message comes…
Could not get plugins
    Getting plugins on node "8cf7f4b5-d19f-469e-b1ab-d71e58334d91" failed: Error: cannot GET https://serverip/api/cluster/8cf7f4b5-d19f-469e-b1ab-d71e58334d91/plugins (500)
    Could not get JVM information
    Getting JVM information for node '8cf7f4b5-d19f-469e-b1ab-d71e58334d91' failed: Error: cannot GET https://serverip:9000/api/cluster/8cf7f4b5-d19f-469e-b1ab-d71e58334d91/jvm (500)
here the graylog server.log
2019-03-28T06:41:05.779-04:00 WARN  [ProxiedResource] Unable to call https://serverip:9000/api/system/metrics/multiple on node <8cf7f4b5-d19f-469e-b1ab-d71e58334d91>
javax.net.ssl.SSLPeerUnverifiedException: Hostname serverip not verified:
    subjectAltNames: [my domian]
        at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:329) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:282) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:167) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114) ~[graylog.jar:?]
        at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
        at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
        at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
        at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
        at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_201]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_201]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_201]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_201]
I am using CA singed certificates that does not have the ip of Gray log server and even hostname.
it has my domain FQDN and IP which is configured on Apache proxy.
Please share some inputs.
you have not all needed URIs in your cert…
Sorry, I did not get.
I need that URI in my certificate or not? if not then why graylog is complaining about the hostname not verified.
your certificate needs all IPs and URIs that might be used to connect to the URL/Graylog.
I have created the self-signed certificate with graylog server hostname and IP and now this issue resolved.
Thank You @jan
