i want to run graylog2-web-interface as separate application in production
He Manjunath,
what is your question? What did you missed from the docs?
as web interface is part of graylog i want to run one more instance of web interface with connects to graylog backed
i was able to run in development mode but not sure how to deploy it in production
thanks
Why? The web interface is a single-page application (SPA) and once the client has loaded the assets, the running web application will only communicate with the Graylog REST API.
Maybe adding a caching reverse-proxy in front would help if you have scaling problems with the web interface (which would genuinely surprise me).
i don’t have any problem with scaling,
there are too many features in graylog which are not used by my users
i just want to show minimum things to users like streams, search, and alert for this i am planing to build new app and i thought of reusing existing code
You can find the code of the Graylog web interface on GitHub:
