Custom Web Interface
I want to customize the web interface with changing some styles.
What all are the steps I need to take care for the same as I tried to change some css using the source code in the “https://github.com/Graylog2/graylog2-server/tree/2.3.1/graylog2-web-interface”, however Iam unable to build this code using maven and not sure how to get the tar file to execute the graylog again in the server.
Any sort of help appreciated on this;
Hi @ZAMS
You may want to look at the following:
Hi @Ponet,
Thanks for the quick response.
I referred “https://github.com/Graylog2/graylog2-server/tree/2.3.1/graylog2-web-interface” this front end code written in react JS. Can we update based on this or shall I start looking on the github code repo shared by you. Also am not getting how we can build this code and deploy again in server to run the graylog properly!!
In order to compile the graylog jar files, you will be want to look at the links I posted above :slight_smile:
