Graylog Web Interface Language
Dear Graylog,
Is my understanding correct that Graylog only supports English as a language for the web interface?
If I wanted to translate the web interface to Korean as an example, I would have to do it within the source code of the web interface and compile.
Cheers
Jake
Yes
yes
Hi Jan,
I am assuming this would also need to be done within plugins as well?
Kind Regards
Jake
yes - as we do not have built in support to assist translation.
I was just about to ask: is Graylog built modularly, in such a way that all the messages and text field are pulled from a separate table or source file? That would make life a lot easier, when trying to offer translations. It’s an approach many project use: translators would simply have to copy the template text-string file and edit it for their own language.
it is not
Jan,
Been doing some research on localisation.
If i wanted to add a language, it would roughly consist of
  • Adding npm packages to support localisation as out of the box npm does not support any other language than english
  • Modifying source code to include localisation support
I was considering using the react-intl or i18next for localisation.
What do you think?
Cheers
Jake
What do you think?
have fun.
You need to touch nearly all parts of Graylog so you need to make this a continuing task - all updates that are done by the Graylog team would need to be transfered to your repository and checked manually.
A big, new major version would of course be a great moment for big sweeping changes like switching to modular UI texts. But since 3.0 is right around the corner, that’s a bit too late. Perhaps for 4.0? :wink:
make a wish (feature request) over in github and the gods of product managment might accept your prey.
Hi Jan,
Have graylog-project-cli building with command line maven. I have installed all dependencies as well such as mongodb / elasticsearch
In the github repo screenshot, it shows a server run configuration in idea. If I go to Run/Debug configurations, I can see an option to create the same screenshot.
I thought about setting it up as a maven project as shown below
But that does not seem to be correct.
Any help appreciated as I would like to get a full working dev server.
Cheers
Jake
You should run it as Java Application with following configurations:
You also need a NPM configuration which will provide you with the frontend dev server:
Since you have a working build I am sure you can take on from here, but I’ll try to help you where I can.
Does bribery with wine and cheese from France work to have the prayers accepted faster? :wink:
Hi Konrad,
I am nearly complete, I have just a couple of the questions.
  1. in your NPM configuration screenshot, you are running a locally installed version, not one in the graylog source tree correct?
  2. I cant seem to select the runner class as in the screenshot below. Have I missed a Java dependancy somewhere? I have open-jdk 1.8 installed or is it just that I don’t know where to find the runner class selection.
Cheers
Jake
Montagny Premier CRU plus saucisson and baquette monsieur
Omelette du fromage!
Hi Magneton,
At first happy new year!
  1. Yes I locally installed node, since the node installations from graylog are transient and might change version or names.
  2. Did you import your project via: maven? That should have find the runner module.
Sorry for the belated answer, but I enjoyed my holidays computer free :slight_smile:
Hi Konrad,
I do holidays pretty much computer free as well except for first thing in the morning as I am a early riser.
I imported the project as a maven project from the graylog2 server directory in the source. IDEA said I had an unmanaged pom.xml and did I want to use maven, so I said ‘yes’.
I will check and come back to you.
Kind Regards
Jake
Hi Konrad,
OK, I solved it. Just for reference for others, you need to import the graylog-parent project not the graylog2-server directory as a maven project then you can setupthe configuration correctly.
I also had to remove the node options to get node to start within IDEA.
However, it looks like my config file is invalid according to below
.shared.plugins.PluginLoader - Plugin directory /home/xxxx/graylog-project-repos/graylog2-server/plugin does not exist, not loading plugins.
2019-01-02 10:00:42,967 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: AWS plugins 3.0.0-alpha.6-SNAPSHOT [org.graylog.aws.AWSPlugin]
2019-01-02 10:00:42,968 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 3.0.0-alpha.6-SNAPSHOT [org.graylog.plugins.collector.CollectorPlugin]
2019-01-02 10:00:42,970 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Threat Intelligence Plugin 3.0.0-alpha.6-SNAPSHOT [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2019-01-02 10:00:42,990 ERROR: org.graylog2.bootstrap.CmdLineTool - Invalid configuration
com.github.joschi.jadconfig.ValidationException: Parent path /etc/graylog/server for Node ID file at /etc/graylog/server/node-id is not a directory
at org.graylog2.Configuration$NodeIdFileValidator.validate(Configuration.java:296) ~[classes/:?]
at org.graylog2.Configuration$NodeIdFileValidator.validate(Configuration.java:284) ~[classes/:?]
at com.github.joschi.jadconfig.JadConfig.validateParameter(JadConfig.java:215) ~[jadconfig-0.13.0.jar:?]
at com.github.joschi.jadconfig.JadConfig.processClassFields(JadConfig.java:148) ~[jadconfig-0.13.0.jar:?]
at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:99) ~[jadconfig-0.13.0.jar:?]
at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:351) [classes/:?]
at org.graylog2.bootstrap.CmdLineTool.readConfiguration(CmdLineTool.java:344) [classes/:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:178) [classes/:?]
at org.graylog2.bootstrap.Main.main(Main.java:44) [classes/:?]
Process finished with exit code 1
I think I am nearly there, just need to solve the the plugin directory not existing and the node-id.
Any help
Cheers
Jake
Konrad,
Look what I have running
For final reference, I had to set graylog to listen on localhost address and comment out the node-id location in the graylog-server configuration file.
I suppose the next test is to get the localisation packages into npm and make sure that works within the package.json
After that the fun really begins…
Cheers
Jake
