How to limit dashboard results in GRaylog 3.3?
Hi everyone,
I recently upgraded Graylog to 3.3 and I to be honest, I like new design and colors. New dashboard and widgets design is also pretty, but it seems I can’t find the feature to limit the number of results in the widget. For example, I used to have before upgrade widget on a dashboard Top 10 source ports, and I would chose 10 ports max. But I don’t that in new version. All my old widgets are limited to 3 results, and if I create a new one, it shows 20.
Cheers
he @facyber
you can see how to make this happen here: Dashboard Widgets Customization options
Oh never crossed my mind to click on that and edit it. That’s what I needed, and it works. Thanks!
