Sources dashboard not more then 15 Hosts
Hello Graylog community
I need to see all Hosts (more then 100) on the source dashboard but on my graylog 3.3 i see only maximum 15 hosts on the dashboard. How to solve it?
Best regards
Tigo
You need to edit widget and click on field ( @field_name ) in ROWS or COLUMNS, and there you can select max number of results.
thanks but cant find @field_name. I have graylog 3.3 opensource version.
You need to edit widgets Selected sources and Messages per Source, click on source in ROWS section and change value Number of values.
