Hi, I have a problem when I want to generate a report from the logs widget of any dashboard. I have noticed that it has a limit of about 1000 lines, so many times it does not print all the lines of that widget that I need. I have tried several things (modifying the server.conf, in elasticsearch, editing widget, etc.), searching for information, etc., without success.
I am currently using Graylog 6.0.5 on Ubuntu, but the same thing happened to me in previous versions.
Let’s see if you can give me some ideas or solutions, thanks.
