jeasoncz
(Jeasoncz)
May 29, 2024, 11:55am
1
In graylog version 5,6 is missing
Missing API endpoint
post /dashboards/{dashboardId}/widgets in graylog version 5.6
How do you display via API the widget data you create on a dashboard?
Unfortunately the aggregations in the search are outdated and offer a maximum of 15 rows. and it is not possible to increase this number.
Thank you.
There’s an API Reports/AvailableWidget that returns all dashboards and widgets.
Looking back all the way to 4.3 I couldn’t see that API. It seems to have been deprecated and removed a long time ago.
jeasoncz
(Jeasoncz)
May 29, 2024, 2:24pm
3
in new version 6.0.2 missing report/AvailableWidget in api
That API does exist in 6.0.x. Unhelpfully, the name is different from the URL. Sorry about that.
jeasoncz
(Jeasoncz)
June 4, 2024, 2:40pm
5
this is a plugin, it does not include Graylog in the base.
Where can I download it and how do I install it?
Thank you for your advice.
It’s an Enterprise feature. You can get a free 2GB Enterprise license here .
jeasoncz
(Jeasoncz)
June 5, 2024, 8:02am
7
thank you, we use open source and I am looking for a solution to get out aggregated data. without buying Enterprise license
Frankly I doubt it was intentional that this capability was removed from Open.
Go ahead and open a feature request. Thx.
jeasoncz
(Jeasoncz)
June 14, 2024, 1:30pm
9
good day, could you please advise me where to open it ? Thank you
