How to compare two counting queries?
Hi everyone! I need to compare the result of these two counting queries, I did not find a way, does it exist?
Environmental information
Graylog 3.3.5
Operating system information
  • Ubuntu
Regards!
Hello
What kind of results are you looking for? Meaning, do you need to combine the widgets, show the count difference, etc…?
Hi @gsmith ! Thanks for your reply, i need to show the difference between for example “cassandra-10” count.
Using Graylog 4.2 I did some testing with widgets and the only thing I could come up that I think you wanted is shown below.
A brief description of this widget is counting by source and user using Cardinality.
Since your using 3.3.5 Maybe take a look here.
https://archivedocs.graylog.org/en/3.3/pages/searching/widgets.html#widgets
Hope that helps
