manjukb002
(Manjunath)
1
I want to fetch data from a elastic index which is linked with a stream
can you give some code sample’s ??
can i use UniversalSearchStore to do any kind of search if so how ??
Manju
manjukb002
(Manjunath)
3
@jan im working on an plugin where i need to fetch data from graylog stream how can i do that ??
should i do new connection to elastic and do it ?
or is there any build in graylog server function which i can call ??
please help
jochen
(Jochen)
4
Take a look at the Searches and Indices classes.
manjukb002
(Manjunath)
5
is there any way i can query for index “xxxx” which is not mapped with any stream
after analysing this classes i feel query happens only through stream id like this
final TermsResult terms = searches.terms("metricbeat_system_cpu_idle_pctfield", 0, "streams:59ce8d2568521b04a981bca3", null, range);
final SearchResult searchResult = searches.search("*", range, 5, 0, Sorting.DEFAULT);
is there any way i can pass my index name so that this actually searches only on my index
any suggestion will be helpful
Manju
manjukb002
(Manjunath)
7
so how can i achieve this scenario ??
jochen
(Jochen)
8
Either write the functionality yourself and create a pull request in the graylog2-server repository, or try to achieve your goal in a different way.
