I have graylog (2.2.3) and i want query its elasticsearch (2.4.4).
I add datasource elasticsearch 2x, i can query but when i query i dont have the same amount of data :
With same query on 5 minutes
From Graylog : 8796 data returned
From Grafana : 57 data returned
Grafana datasource configuration :
Index name : graylog*
Timestamp field name : timestamp
Pattern : no pattern
Version : 2.x
Why do not I get the same results?
jochen
(Jochen)
July 20, 2017, 2:43pm
2
What query are you running exactly?
Which indices does Grafana use and which indices does Graylog use for the same query?
Graylog :
"from": 0,
"size": 150,
"query": {
"bool": {
"must": {
"query_string": {
"query": "\"myrouter\" AND (\"990-D\" OR \"991-D\" OR \"default-D\")",
"allow_leading_wildcard": true
"filter": {
"bool": {
"must": {
"range": {
"timestamp": {
"from": "2017-07-20 13:37:51.507",
"to": "2017-07-20 13:42:51.507",
"include_lower": true,
"include_upper": true
"sort": [
"timestamp": {
"order": "desc"
"highlight": {
"require_field_match": false,
"fields": {
"fragment_size": 0,
"number_of_fragments": 0
Grafana :
{“search_type”:“count”,“ignore_unavailable”:true,“index”:“graylog*”}
{“size”:0,“query”:{“bool”:{“filter”:[{“range”:{“timestamp”:{“gte”:“1500557461375”,“lte”:“1500557761375”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:"“myrouter” AND (“990-D” OR “991-D” OR “default-D”)"}}]}},“aggs”:{“2”:{“date_histogram”:{“interval”:“2s”,“field”:“timestamp”,“min_doc_count”:0,“extended_bounds”:{“min”:“1500557461375”,“max”:“1500557761375”},“format”:“epoch_millis”},“aggs”:{}}}}
Indice on graylog :
graylog2_25
graylog2_24
graylog_docker_1
graylog_vyos_rt01_0
graylog_docker_2
graylog_vyos_rt01_1
graylog2_23
graylog2_22
graylog2_21
Indice for grafana data source : graylog*
jochen
(Jochen)
July 20, 2017, 3:55pm
5
Try using the exact same query in Grafana that has been generated by Graylog.
Other than that, I suggest asking the Grafana community since this isn’t exactly an issue with Graylog.
