Graylog startup failed from manual setup
I’m currently running Graylog 4.0.6 from manual setup, but when i started it up by ./graylogctl run, i failed
[root@loganalysis-5876e1ad bin]# ./graylogctl run
Running graylog-server …
Java HotSpot™ 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
2021-04-12 14:04:24,272 WARN : org.graylog2.shared.security.tls.DefaultTLSProtocolProvider - JRE doesn’t support all default TLS protocols. Changing <[TLSv1.2, TLSv1.3]> to <[TLSv1.2]>
2021-04-12 14:04:24,645 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: AWS plugins 4.0.6 [org.graylog.aws.AWSPlugin]
2021-04-12 14:04:24,646 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 4.0.6 [org.graylog.plugins.collector.CollectorPlugin]
2021-04-12 14:04:24,647 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Threat Intelligence Plugin 4.0.6 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2021-04-12 14:04:24,647 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elasticsearch 6 Support 4.0.6+40b7be5 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2021-04-12 14:04:24,647 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elasticsearch 7 Support 4.0.6+40b7be5 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2021-04-12 14:04:25,653 INFO : org.graylog2.bootstrap.CmdLineTool - Running with JVM arguments: -Djava.library.path=/usr/local/lib -Xms1024m -Xmx2048m -XX:MaxPermSize=256m -Djava.awt.headless=true -Dsun.net.client.defaultReadTimeout=60000 -Djmagick.systemclassloader=no -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.ttl=300
2021-04-12 14:04:26,499 INFO : org.hibernate.validator.internal.util.Version - HV000001: Hibernate Validator null
2021-04-12 14:04:27,090 INFO : org.graylog2.shared.system.stats.SigarService - Failed to load SIGAR. Falling back to JMX implementations.
2021-04-12 14:04:54,533 INFO : org.graylog2.shared.buffers.InputBufferImpl - Message journal is enabled.
2021-04-12 14:04:54,674 INFO : org.graylog2.plugin.system.NodeId - Node ID: b4442275-32f1-4e67-b6af-e8a98160cce2
2021-04-12 14:04:55,719 INFO : org.graylog.shaded.kafka09.log.LogManager - Loading logs.
2021-04-12 14:04:56,019 INFO : org.graylog.shaded.kafka09.log.LogManager - Logs loading complete.
2021-04-12 14:04:56,024 INFO : org.graylog2.shared.journal.KafkaJournal - Initialized Kafka based journal at data/journal
2021-04-12 14:04:56,220 INFO : org.mongodb.driver.cluster - Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2021-04-12 14:04:56,520 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2021-04-12 14:04:56,756 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:1, serverValue:17}] to localhost:27017
2021-04-12 14:04:56,781 INFO : org.mongodb.driver.cluster - Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 23]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=18446119}
2021-04-12 14:04:56,814 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:2, serverValue:18}] to localhost:27017
2021-04-12 14:04:57,570 INFO : org.graylog2.shared.buffers.InputBufferImpl - Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2021-04-12 14:04:58,765 INFO : org.graylog2.storage.providers.ElasticsearchVersionProvider - Elasticsearch cluster is running v6.8.10
2021-04-12 14:05:00,210 INFO : io.searchbox.client.AbstractJestClient - Setting server pool to a list of 1 servers: [http://10.170.145.189:9200]
2021-04-12 14:05:00,211 INFO : io.searchbox.client.JestClientFactory - Using multi thread/connection supporting pooling connection manager
2021-04-12 14:05:00,456 INFO : io.searchbox.client.JestClientFactory - Using custom ObjectMapper instance
2021-04-12 14:05:00,456 INFO : io.searchbox.client.JestClientFactory - Node Discovery disabled…
2021-04-12 14:05:00,456 INFO : io.searchbox.client.JestClientFactory - Idle connection reaping disabled…
2021-04-12 14:05:01,893 INFO : org.graylog2.shared.buffers.ProcessBuffer - Initialized ProcessBuffer with ring size <65536> and wait strategy .
2021-04-12 14:05:02,195 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-04-12 14:05:02,216 INFO : org.graylog2.buffers.OutputBuffer - Initialized OutputBuffer with ring size <65536> and wait strategy .
2021-04-12 14:05:02,236 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:3, serverValue:19}] to localhost:27017
2021-04-12 14:05:02,289 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-04-12 14:05:02,394 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-04-12 14:05:02,483 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-04-12 14:05:02,517 WARN : org.graylog.plugins.map.geoip.GeoIpResolverEngine - GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-04-12 14:05:04,287 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server 4.0.6+40b7be5 starting up
2021-04-12 14:05:04,288 INFO : org.graylog2.bootstrap.ServerBootstrap - JRE: Oracle Corporation 1.8.0_20 on Linux 4.18.0-193.el8.jd_001.x86_64
2021-04-12 14:05:04,288 INFO : org.graylog2.bootstrap.ServerBootstrap - Deployment: unknown
2021-04-12 14:05:04,288 INFO : org.graylog2.bootstrap.ServerBootstrap - OS: CentOS Linux 7 (Core) (centos)
2021-04-12 14:05:04,288 INFO : org.graylog2.bootstrap.ServerBootstrap - Arch: amd64
2021-04-12 14:05:04,363 INFO : org.graylog2.shared.initializers.PeriodicalsService - Starting 30 periodicals …
2021-04-12 14:05:04,382 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2021-04-12 14:05:04,411 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:4, serverValue:20}] to localhost:27017
2021-04-12 14:05:04,472 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2021-04-12 14:05:04,476 INFO : org.graylog2.shared.initializers.PeriodicalsService - Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2021-04-12 14:05:04,478 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2021-04-12 14:05:04,481 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2021-04-12 14:05:04,482 INFO : org.graylog2.shared.initializers.PeriodicalsService - Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2021-04-12 14:05:04,482 INFO : org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration - Legacy default stream has no connections, no migration needed.
2021-04-12 14:05:04,482 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2021-04-12 14:05:04,485 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2021-04-12 14:05:04,486 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2021-04-12 14:05:04,493 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2021-04-12 14:05:04,569 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2021-04-12 14:05:04,583 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:5, serverValue:21}] to localhost:27017
2021-04-12 14:05:04,574 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2021-04-12 14:05:04,593 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2021-04-12 14:05:04,594 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2021-04-12 14:05:04,596 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2021-04-12 14:05:04,597 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2021-04-12 14:05:04,597 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2021-04-12 14:05:04,602 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2021-04-12 14:05:04,704 INFO : org.graylog2.shared.initializers.PeriodicalsService - Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2021-04-12 14:05:04,705 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2021-04-12 14:05:04,722 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2021-04-12 14:05:04,723 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2021-04-12 14:05:04,723 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2021-04-12 14:05:04,724 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2021-04-12 14:05:04,725 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2021-04-12 14:05:04,726 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2021-04-12 14:05:04,731 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2021-04-12 14:05:04,733 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2021-04-12 14:05:04,734 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2021-04-12 14:05:04,737 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2021-04-12 14:05:05,352 INFO : org.mongodb.driver.connection - Opened connection [connectionId{localValue:6, serverValue:22}] to localhost:27017
2021-04-12 14:05:47,599 WARN : org.glassfish.jersey.internal.Errors - The following warnings have been detected: WARNING: Unknown HK2 failure detected:
MultiException stack 1 of 2
java.lang.VerifyError: Uninitialized object exists on backward branch 75
Exception Details:
scala/collection/immutable/Vector1.map(Lscala/Function1;)Lscala/collection/immutable/Vector; @103: goto
Reason:
Error exists in the bytecode
Bytecode:
0x0000000: bb00 0259 b200 3657 2ab6 0011 4d03 3e1d
0x0000010: 2cbe a200 692c 1d32 3a04 2b19 04b9 0055
0x0000020: 0200 3a05 1904 1905 a500 4c2c bebd 0042
0x0000030: 3a06 1d03 a400 0c2c 0319 0603 1db8 005b
0x0000040: 1906 1d19 0553 1d04 6036 0715 072c bea2
0x0000050: 001b 1906 1507 2b2c 1507 32b9 0055 0200
0x0000060: 5315 0704 6036 07a7 ffe4 1906 013a 063a
0x0000070: 08a7 000d 1d04 603e a7ff 972c 3a08 1908
0x0000080: 014d 013a 0401 3a05 013a 0601 3a08 b700
0x0000090: 2cb0
Stackmap Table:
full_frame(@15,{Object[#2],Object[#82],Object[#36],Integer},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@64,{Object[#2],Object[#82],Object[#36],Integer,Object[#66],Object[#66],Object[#36]},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@75,{Object[#2],Object[#82],Object[#36],Integer,Object[#66],Object[#66],Object[#36],Integer},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@106,{Object[#2],Object[#82],Object[#36],Integer,Object[#66],Object[#66],Object[#36],Integer},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@116,{Object[#2],Object[#82],Object[#36],Integer,Object[#66],Object[#66]},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@123,{Object[#2],Object[#82],Object[#36],Integer},{Uninitialized[#0],Uninitialized[#0]})
full_frame(@126,{Object[#2],Object[#82],Object[#36],Integer,Top,Top,Top,Top,Object[#36]},{Uninitialized[#0],Uninitialized[#0]})
at scala.collection.immutable.VectorBuilder.result(Vector.scala:1628)
at scala.collection.immutable.VectorBuilder.result(Vector.scala:1349)
at scala.collection.immutable.Range.map(Range.scala:59)
at com.fasterxml.jackson.module.scala.util.TopologicalSorter.dotProduct(FactorySorter.scala:72)
at com.fasterxml.jackson.module.scala.util.TopologicalSorter.$anonfun$toList$4(FactorySorter.scala:54)
at com.fasterxml.jackson.module.scala.util.TopologicalSorter$$Lambda$483/99560031.apply$mcVI$sp(Unknown Source)
at scala.collection.immutable.Range.foreach$mVc$sp(Range.scala:190)
at com.fasterxml.jackson.module.scala.util.TopologicalSorter.toList(FactorySorter.scala:53)
at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule$$anon$1.(SeqDeserializerModule.scala:36)
at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule.$anonfun$$init$$1(SeqDeserializerModule.scala:11)
at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule.$anonfun$$init$$1$adapted(SeqDeserializerModule.scala:11)
at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule$$Lambda$463/1002740506.apply(Unknown Source)
at com.fasterxml.jackson.module.scala.JacksonModule.$anonfun$setupModule$1(JacksonModule.scala:64)
at com.fasterxml.jackson.module.scala.JacksonModule.$anonfun$setupModule$1$adapted(JacksonModule.scala:64)
at com.fasterxml.jackson.module.scala.JacksonModule$$Lambda$479/108450269.apply(Unknown Source)
at scala.collection.immutable.List.foreach(List.scala:333)
at com.fasterxml.jackson.module.scala.JacksonModule.setupModule(JacksonModule.scala:64)
at com.fasterxml.jackson.module.scala.JacksonModule.setupModule$(JacksonModule.scala:46)
at com.fasterxml.jackson.module.scala.DefaultScalaModule.setupModule(DefaultScalaModule.scala:17)
at com.fasterxml.jackson.databind.ObjectMapper.registerModule(ObjectMapper.java:751)
at com.fasterxml.jackson.databind.ObjectMapper.registerModules(ObjectMapper.java:951)
at com.fasterxml.jackson.databind.ObjectMapper.findAndRegisterModules(ObjectMapper.java:1029)
at org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider.findAndRegisterModules(DefaultJacksonJaxbJsonProvider.java:44)
at org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider.(DefaultJacksonJaxbJsonProvider.java:33)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
at org.glassfish.hk2.utilities.reflection.ReflectionHelper.makeMe(ReflectionHelper.java:1356)
at org.jvnet.hk2.internal.ClazzCreator.createMe(ClazzCreator.java:248)
at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:342)
at org.jvnet.hk2.internal.SystemDescriptor.create(SystemDescriptor.java:463)
at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:59)
at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:47)
at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture$1.call(Cache.java:74)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture.run(Cache.java:131)
at org.glassfish.hk2.utilities.cache.Cache.compute(Cache.java:176)
at org.jvnet.hk2.internal.SingletonContext.findOrCreate(SingletonContext.java:98)
at org.jvnet.hk2.internal.Utilities.createService(Utilities.java:2102)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:93)
at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:67)
at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager.lambda$getAllServiceHolders$0(AbstractHk2InjectionManager.java:136)
at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager$$Lambda$453/1497805060.apply(Unknown Source)
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
at java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1235)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:512)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:502)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499)
at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager.getAllServiceHolders(AbstractHk2InjectionManager.java:140)
at org.glassfish.jersey.inject.hk2.ImmediateHk2InjectionManager.getAllServiceHolders(ImmediateHk2InjectionManager.java:30)
at org.glassfish.jersey.internal.inject.Providers.getServiceHolders(Providers.java:307)
at org.glassfish.jersey.internal.inject.Providers.getCustomProviders(Providers.java:151)
at org.glassfish.jersey.message.internal.MessageBodyFactory.initialize(MessageBodyFactory.java:219)
at org.glassfish.jersey.message.internal.MessageBodyFactory$MessageBodyWorkersConfigurator.postInit(MessageBodyFactory.java:114)
at org.glassfish.jersey.server.ApplicationHandler.lambda$initialize$2(ApplicationHandler.java:349)
at org.glassfish.jersey.server.ApplicationHandler$$Lambda$448/376323503.accept(Unknown Source)
at java.util.Arrays$ArrayList.forEach(Arrays.java:3880)
at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:349)
at org.glassfish.jersey.server.ApplicationHandler.lambda$initialize$1(ApplicationHandler.java:293)
at org.glassfish.jersey.server.ApplicationHandler$$Lambda$402/225987977.call(Unknown Source)
at org.glassfish.jersey.internal.Errors.process(Errors.java:292)
at org.glassfish.jersey.internal.Errors.process(Errors.java:274)
at org.glassfish.jersey.internal.Errors.processWithException(Errors.java:232)
at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:292)
at org.glassfish.jersey.server.ApplicationHandler.(ApplicationHandler.java:259)
at org.glassfish.jersey.server.ApplicationHandler.(ApplicationHandler.java:246)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.(GrizzlyHttpContainer.java:310)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpServerFactory.createHttpServer(GrizzlyHttpServerFactory.java:163)
at org.graylog2.shared.initializers.JerseyService.setUp(JerseyService.java:313)
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:194)
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:151)
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62)
at com.google.common.util.concurrent.Callables$4.run(Callables.java:119)
at java.lang.Thread.run(Thread.java:745)
MultiException stack 2 of 2
java.lang.IllegalStateException: Unable to perform operation: create on org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider
at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:369)
below is the 2nd part of my error log
2021-04-12 14:05:47,606 INFO : org.graylog2.shared.initializers.InputSetupService - Triggering launching persisted inputs, node transitioned from Uninitialized?[LB:DEAD] to Failed?[LB:DEAD]
2021-04-12 14:05:47,608 ERROR: org.graylog2.shared.initializers.InputSetupService - Not starting any inputs because lifecycle is: Failed?[LB:DEAD]
2021-04-12 14:05:47,670 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
2021-04-12 14:05:47,672 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
2021-04-12 14:05:47,673 INFO : org.graylog2.system.shutdown.GracefulShutdownService - Running graceful shutdown for <1> shutdown hooks
2021-04-12 14:05:47,675 INFO : org.graylog2.shared.journal.JournalReader - Stopping.
2021-04-12 14:05:47,674 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
2021-04-12 14:05:47,675 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
2021-04-12 14:05:47,675 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
2021-04-12 14:05:47,677 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
2021-04-12 14:05:47,679 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
2021-04-12 14:05:47,679 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
2021-04-12 14:05:47,679 INFO : org.graylog.shaded.kafka09.log.LogManager - Shutting down.
2021-04-12 14:05:47,679 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
2021-04-12 14:05:47,679 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
2021-04-12 14:05:47,683 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
2021-04-12 14:05:47,684 INFO : org.graylog2.system.shutdown.GracefulShutdownService - Initiate shutdown for
2021-04-12 14:05:47,685 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.VersionCheckThread] complete, took <0ms>.
2021-04-12 14:05:47,687 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
2021-04-12 14:05:47,687 INFO : org.graylog2.system.shutdown.GracefulShutdownService - Finished shutdown for , took 0 ms
2021-04-12 14:05:47,687 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
2021-04-12 14:05:47,688 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2021-04-12 14:05:47,688 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
2021-04-12 14:05:47,688 INFO : org.graylog2.lookup.LookupDataAdapterRefreshService - Stopping 0 jobs
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.TrafficCounterCalculator].
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.TrafficCounterCalculator] complete, took <0ms>.
2021-04-12 14:05:47,690 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] complete, took <0ms>.
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] complete, took <0ms>.
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog2.periodical.ESVersionCheckPeriodical].
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog2.periodical.ESVersionCheckPeriodical] complete, took <0ms>.
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] complete, took <0ms>.
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
2021-04-12 14:05:47,691 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] complete, took <0ms>.
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob] complete, took <0ms>.
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp] complete, took <0ms>.
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
2021-04-12 14:05:47,692 INFO : org.graylog2.shared.initializers.PeriodicalsService - Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
2021-04-12 14:05:47,780 INFO : org.graylog.shaded.kafka09.log.LogManager - Shutdown complete.
2021-04-12 14:05:47,786 INFO : org.graylog2.buffers.Buffers - Waiting until all buffers are empty.
2021-04-12 14:05:47,787 INFO : org.graylog2.buffers.Buffers - All buffers are empty. Continuing.
2021-04-12 14:05:47,789 INFO : org.graylog2.initializers.OutputSetupService - Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2021-04-12 14:06:17,690 ERROR: org.graylog2.bootstrap.ServerBootstrap - Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], UrlWhitelistService [TERMINATED], JournalReader [TERMINATED], StreamCacheService [TERMINATED], OutputSetupService [TERMINATED], LookupTableService [TERMINATED], GracefulShutdownService [TERMINATED], EtagService [TERMINATED], ConfigurationEtagService [TERMINATED], PeriodicalsService [TERMINATED], KafkaJournal [TERMINATED], BufferSynchronizerService [TERMINATED]], FAILED=[JerseyService [FAILED]]}
2021-04-12 14:06:17,691 ERROR: org.graylog2.bootstrap.ServerBootstrap - Graylog startup failed. Exiting. Exception was:
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:773) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:585) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:316) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:161) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:212) [graylog.jar:?]
Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 2 exceptions. They are:
  1. java.lang.VerifyError: Uninitialized object exists on backward branch 75
    Exception Details:
    Reason:
    Bytecode:
    0x0000090: 2cb0
    Stackmap Table:
  2. java.lang.IllegalStateException: Unable to perform operation: create on org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider
    at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:368) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.SystemDescriptor.create(SystemDescriptor.java:463) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:59) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.SingletonContext$1.compute(SingletonContext.java:47) ~[graylog.jar:?]
    at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture$1.call(Cache.java:74) ~[graylog.jar:?]
    at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_20]
    at org.glassfish.hk2.utilities.cache.Cache$OriginThreadAwareFuture.run(Cache.java:131) ~[graylog.jar:?]
    at org.glassfish.hk2.utilities.cache.Cache.compute(Cache.java:176) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.SingletonContext.findOrCreate(SingletonContext.java:98) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.Utilities.createService(Utilities.java:2102) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:93) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.ServiceHandleImpl.getService(ServiceHandleImpl.java:67) ~[graylog.jar:?]
    at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager.lambda$getAllServiceHolders$0(AbstractHk2InjectionManager.java:136) ~[graylog.jar:?]
    at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager$$Lambda$453/1497805060.apply(Unknown Source) ~[?:?]
    at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:1.8.0_20]
    at java.util.LinkedList$LLSpliterator.forEachRemaining(LinkedList.java:1235) ~[?:1.8.0_20]
    at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:512) ~[?:1.8.0_20]
    at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:502) ~[?:1.8.0_20]
    at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_20]
    at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_20]
    at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:1.8.0_20]
    at org.glassfish.jersey.inject.hk2.AbstractHk2InjectionManager.getAllServiceHolders(AbstractHk2InjectionManager.java:140) ~[graylog.jar:?]
    at org.glassfish.jersey.inject.hk2.ImmediateHk2InjectionManager.getAllServiceHolders(ImmediateHk2InjectionManager.java:30) ~[graylog.jar:?]
    at org.glassfish.jersey.internal.inject.Providers.getServiceHolders(Providers.java:307) ~[graylog.jar:?]
    at org.glassfish.jersey.internal.inject.Providers.getCustomProviders(Providers.java:151) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.MessageBodyFactory.initialize(MessageBodyFactory.java:219) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.MessageBodyFactory$MessageBodyWorkersConfigurator.postInit(MessageBodyFactory.java:114) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.lambda$initialize$2(ApplicationHandler.java:349) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler$$Lambda$448/376323503.accept(Unknown Source) ~[?:?]
    at java.util.Arrays$ArrayList.forEach(Arrays.java:3880) ~[?:1.8.0_20]
    at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:349) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.lambda$initialize$1(ApplicationHandler.java:293) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler$$Lambda$402/225987977.call(Unknown Source) ~[?:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:292) ~[graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:274) ~[graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.processWithException(Errors.java:232) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.initialize(ApplicationHandler.java:292) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.(ApplicationHandler.java:259) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.(ApplicationHandler.java:246) ~[graylog.jar:?]
    at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.(GrizzlyHttpContainer.java:310) ~[graylog.jar:?]
    at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpServerFactory.createHttpServer(GrizzlyHttpServerFactory.java:163) ~[graylog.jar:?]
    at org.graylog2.shared.initializers.JerseyService.setUp(JerseyService.java:313) ~[graylog.jar:?]
    at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:194) ~[graylog.jar:?]
    at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:151) ~[graylog.jar:?]
    at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
    at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
    at java.lang.Thread.run(Thread.java:745) ~[?:1.8.0_20]
    Caused by: java.lang.VerifyError: Uninitialized object exists on backward branch 75
    Exception Details:
    Reason:
    Bytecode:
    0x0000090: 2cb0
    Stackmap Table:
    at scala.collection.immutable.VectorBuilder.result(Vector.scala:1628) ~[graylog.jar:?]
    at scala.collection.immutable.VectorBuilder.result(Vector.scala:1349) ~[graylog.jar:?]
    at scala.collection.immutable.Range.map(Range.scala:59) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.util.TopologicalSorter.dotProduct(FactorySorter.scala:72) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.util.TopologicalSorter.$anonfun$toList$4(FactorySorter.scala:54) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.util.TopologicalSorter$$Lambda$483/99560031.apply$mcVI$sp(Unknown Source) ~[?:?]
    at scala.collection.immutable.Range.foreach$mVc$sp(Range.scala:190) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.util.TopologicalSorter.toList(FactorySorter.scala:53) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule$$anon$1.(SeqDeserializerModule.scala:36) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule.$anonfun$$init$$1(SeqDeserializerModule.scala:11) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule.$anonfun$$init$$1$adapted(SeqDeserializerModule.scala:11) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.deser.SeqDeserializerModule$$Lambda$463/1002740506.apply(Unknown Source) ~[?:?]
    at com.fasterxml.jackson.module.scala.JacksonModule.$anonfun$setupModule$1(JacksonModule.scala:64) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.JacksonModule.$anonfun$setupModule$1$adapted(JacksonModule.scala:64) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.JacksonModule$$Lambda$479/108450269.apply(Unknown Source) ~[?:?]
    at scala.collection.immutable.List.foreach(List.scala:333) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.JacksonModule.setupModule(JacksonModule.scala:64) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.JacksonModule.setupModule$(JacksonModule.scala:46) ~[graylog.jar:?]
    at com.fasterxml.jackson.module.scala.DefaultScalaModule.setupModule(DefaultScalaModule.scala:17) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ObjectMapper.registerModule(ObjectMapper.java:751) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ObjectMapper.registerModules(ObjectMapper.java:951) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ObjectMapper.findAndRegisterModules(ObjectMapper.java:1029) ~[graylog.jar:?]
    at org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider.findAndRegisterModules(DefaultJacksonJaxbJsonProvider.java:44) ~[graylog.jar:?]
    at org.glassfish.jersey.jackson.internal.DefaultJacksonJaxbJsonProvider.(DefaultJacksonJaxbJsonProvider.java:33) ~[graylog.jar:?]
    at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:1.8.0_20]
    at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:1.8.0_20]
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:1.8.0_20]
    at java.lang.reflect.Constructor.newInstance(Constructor.java:408) ~[?:1.8.0_20]
    at org.glassfish.hk2.utilities.reflection.ReflectionHelper.makeMe(ReflectionHelper.java:1356) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.ClazzCreator.createMe(ClazzCreator.java:248) ~[graylog.jar:?]
    at org.jvnet.hk2.internal.ClazzCreator.create(ClazzCreator.java:342) ~[graylog.jar:?]
    2021-04-12 14:06:17,713 INFO : org.graylog2.commands.Server - SIGNAL received. Shutting down.
    2021-04-12 14:06:17,721 INFO : org.graylog2.system.shutdown.GracefulShutdown - Graceful shutdown initiated.
    2021-04-12 14:06:17,721 INFO : org.graylog2.system.shutdown.GracefulShutdown - Node status: [Halting?[LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
    2021-04-12 14:06:21,724 INFO : org.graylog2.system.shutdown.GracefulShutdown - Goodbye.
my configuration file as below
is_master = true
http_bind_address = 11.91.145.27:9000
elasticsearch_hosts = http://10.170.145.189:9200
Which java version do you use? Try to use OpenJDK 8, which is the most stable.
[root@loganalysis-5876e1ad /]# java -version
java version “1.8.0_20”
Java™ SE Runtime Environment (build 1.8.0_20-b26)
Java HotSpot™ 64-Bit Server VM (build 25.20-b23, mixed mode)
This is extremelly old version of Java, released in 2014. Don’t try to use this old version, it can’t work. Try to update to latest update version of OpenJDK 8 update 282.
Which linux distribution do you use? Why you didn’t install distribution based package, APT or YUM?
Best is to use distribution version of OpenJDK, for example:
  • Debian: apt-get install openjdk-8-jre
  • Ubuntu: apt-get install openjdk-8-jre-headless
  • CentOS: java-1.8.0-openjdk-headless
Because I’m currently working in a docker where systemctl command is not allowed.
by the way, If I install graylog by YUM, how do I start it up?
linux distribution: CentOS 7
Why not use official docker image by graylog?:
https://docs.graylog.org/en/4.0/pages/installation/docker.html
https://hub.docker.com/r/graylog/graylog
Or if you want to create own image, check how graylog generate images:
Tried, but not allowed, that’s SAD
If I were you I would use official Dockerfile for graylog’s docker image generation as a inspiration and update it from debian commands (apt and so on) to CentOS based:
Then use updated Dockerfile to generate own image
really appreciated your help
when I upgraded my Java JDK to the latest
IT FINALLY WORKS!!!
