Hey! I am looking for help bringing Graylog back to life. It somehow crashed due to a power outage. Since then it does not start correctly. I am probably overlooking something. I suspect an error with jvm settings.
I upgraded Graylog to 4.3 already (on Ubuntu 18.04).
Elasticsearch version is 7.10.2.
Service status
admin@ubuntu_1804:~$ sudo systemctl status graylog-server.service
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-11-18 15:16:05 CET; 28s ago
Docs: http://docs.graylog.org/
Main PID: 7629 (graylog-server)
Tasks: 37 (limit: 4915)
CGroup: /system.slice/graylog-server.service
├─7629 /bin/sh /usr/share/graylog-server/bin/graylog-server
└─7676 /usr/bin/java -Xms2g -Xmx2g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSC
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: End of classname legend:
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: ========================
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:568)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:190)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:113)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at com.google.inject.Guice.createInjector(Guice.java:87)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:490)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:295)
Nov 18 15:16:32 ubuntu_1804 graylog-server[7629]: at org.graylog2.bootstrap.Main.main(Main.java:45)
Graylog server log
2022-11-18T15:16:08.808+01:00 INFO [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-11-18T15:16:10.985+01:00 INFO [CmdLineTool] Loaded plugin: AWS plugins 4.3.9 [org.graylog.aws.AWSPlugin]
2022-11-18T15:16:10.988+01:00 INFO [CmdLineTool] Loaded plugin: Enterprise Integrations 4.3.9 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2022-11-18T15:16:10.990+01:00 INFO [CmdLineTool] Loaded plugin: Integrations 4.3.9 [org.graylog.integrations.IntegrationsPlugin]
2022-11-18T15:16:10.992+01:00 INFO [CmdLineTool] Loaded plugin: Collector 4.3.9 [org.graylog.plugins.collector.CollectorPlugin]
2022-11-18T15:16:10.995+01:00 INFO [CmdLineTool] Loaded plugin: Graylog Enterprise 4.3.9 [org.graylog.plugins.enterprise.EnterprisePlugin]
2022-11-18T15:16:10.998+01:00 INFO [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.3.9 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2022-11-18T15:16:11.000+01:00 INFO [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.3.9 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2022-11-18T15:16:11.003+01:00 INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.3.9 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-11-18T15:16:11.004+01:00 INFO [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.3.9+e2c6648 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-11-18T15:16:11.005+01:00 INFO [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.3.9+e2c6648 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-11-18T15:16:11.109+01:00 INFO [CmdLineTool] Running with JVM arguments: -Xms2g -Xmx2g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2022-11-18T15:16:13.075+01:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-11-18T15:16:13.300+01:00 INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-11-18T15:16:13.470+01:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:34}] to localhost:27017
2022-11-18T15:16:13.489+01:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=9325632}
2022-11-18T15:16:13.540+01:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:35}] to localhost:27017
2022-11-18T15:16:13.628+01:00 INFO [connection] Closed connection [connectionId{localValue:2, serverValue:35}] to localhost:27017 because the pool has been closed.
2022-11-18T15:16:13.637+01:00 INFO [MongoDBPreflightCheck] Connected to MongoDB version 4.0.28
2022-11-18T15:16:13.967+01:00 INFO [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <Elasticsearch:7.10.2>
2022-11-18T15:16:14.291+01:00 INFO [Version] HV000001: Hibernate Validator null
2022-11-18T15:16:25.596+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:25.651+01:00 INFO [NodeId] Node ID: c251c81e-9729-4ec5-9348-7c7132fe8d8d
2022-11-18T15:16:26.202+01:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-11-18T15:16:26.206+01:00 INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-11-18T15:16:26.214+01:00 INFO [connection] Opened connection [connectionId{localValue:3, serverValue:36}] to localhost:27017
2022-11-18T15:16:26.217+01:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1509000}
2022-11-18T15:16:26.224+01:00 INFO [connection] Opened connection [connectionId{localValue:4, serverValue:37}] to localhost:27017
2022-11-18T15:16:27.241+01:00 INFO [ElasticsearchVersionProvider] Elasticsearch cluster is running Elasticsearch:7.10.2
2022-11-18T15:16:28.685+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:29.185+01:00 INFO [connection] Opened connection [connectionId{localValue:5, serverValue:38}] to localhost:27017
2022-11-18T15:16:29.278+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:30.034+01:00 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-11-18T15:16:30.068+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:30.104+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.129+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.687+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.694+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.706+01:00 INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-11-18T15:16:31.715+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.803+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.851+01:00 INFO [InputBufferImpl] Message journal is enabled.
2022-11-18T15:16:31.883+01:00 ERROR [CmdLineTool] Guice error (more detail on log level debug): java.lang.NumberFormatException: For input string: ""
2022-11-18T15:16:31.884+01:00 ERROR [CmdLineTool] Guice error (more detail on log level debug): java.lang.NumberFormatException: For input string: ""
/etc/default/graylog-server
# Path to the java executable.
JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms2g -Xmx2g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow"
# Avoid endless loop with some TLSv1.3 implementations.
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true"
# Fix for log4j CVE-2021-44228
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true"
# Pass some extra args to graylog-server. (i.e. "-d" to enable debug mode)
#GRAYLOG_SERVER_ARGS=""
# Program that will be used to wrap the graylog-server command. Useful to
# support programs like authbind.
#GRAYLOG_COMMAND_WRAPPER=""
Thanks for you help!
