Graylog KO after upgrade to v5
When I start the Graylog service, it goes into error, then tries to start again without ever stopping.
  • OS Information:
    Debian 11
  • Package Version:
    Graylog 5.1.4
    Mongo 6.0.9
    OpenSearch 2.5.0
is_leader = true
password_secret =
root_password_sha2 =
root_timezone = Europe/Paris
http_bind_address = server.domain.lan:9000
elasticsearch_hosts = http://IP_OPENSEARCH:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
auto_restart_inputs = true
INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {default properties file=[cloud_inputs=on, scripting_api_preview=on, search_filter=on, preflight_web=off]}
INFO  [CmdLineTool] Loaded plugin: Aggregation Count Alert Condition 2.2.0 [com.airbus-cyber-security.graylog.AggregationCountPlugin]
INFO  [CmdLineTool] Loaded plugin: Alert Wizard 3.3.0 [com.airbus-cyber-security.graylog.AlertWizardPlugin]
INFO  [CmdLineTool] Loaded plugin: Correlation Count Alert Condition 2.2.0 [com.airbus-cyber-security.graylog.CorrelationCountPlugin]
INFO  [CmdLineTool] Loaded plugin: Logging Alert Notification 2.2.0 [com.airbus-cyber-security.graylog.LoggingAlertPlugin]
INFO  [CmdLineTool] Loaded plugin: AWS plugins 5.1.4 [org.graylog.aws.AWSPlugin]
INFO  [CmdLineTool] Loaded plugin: Integrations 5.1.4 [org.graylog.integrations.IntegrationsPlugin]
INFO  [CmdLineTool] Loaded plugin: Collector 5.1.4 [org.graylog.plugins.collector.CollectorPlugin]
INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 5.1.4+6fa2de3 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 5.1.4+6fa2de3 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
INFO  [CmdLineTool] Loaded plugin: OpenSearch 2 Support 5.1.4+6fa2de3 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.8.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.10.0-24-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.8+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@672b72ba]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=18865913}
INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
INFO  [MongoDBPreflightCheck] Connected to MongoDB version 6.0.9
INFO  [FilePersistedNodeIdProvider] Node ID: 4318a727-7cc4-4614-977e-80ead2452622
INFO  [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <OpenSearch:2.5.0>
INFO  [Version] HV000001: Hibernate Validator null
INFO  [InputBufferImpl] Message journal is enabled.
INFO  [LogManager] Loading logs.
INFO  [LogManager] Logs loading complete.
INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1299454}
INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running OpenSearch:2.5.0
INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
INFO  [DbEntitiesScanner] 16 entities have been scanned and added to DB Entity Catalog, it took 848.6 ms
INFO  [ServerBootstrap] Graylog server 5.1.4+6fa2de3 starting up
INFO  [ServerBootstrap] JRE: Eclipse Adoptium 17.0.8 on Linux 5.10.0-24-amd64
INFO  [ServerBootstrap] Deployment: deb
INFO  [ServerBootstrap] OS: Debian GNU/Linux 11 (bullseye) (debian)
INFO  [ServerBootstrap] Arch: amd64
INFO  [ServerBootstrap] Running 54 migrations...
INFO  [PeriodicalsService] Starting 26 periodicals ...
INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
INFO  [Periodicals] Starting [org.graylog2.periodical.IndexBlockCheck] periodical in [0s], polling every [30s].
INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [1s].
INFO  [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
INFO  [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
INFO  [Periodicals] Starting [org.graylog2.periodical.UserSessionTerminationPeriodical] periodical, running forever.
INFO  [Periodicals] Starting [org.graylog2.telemetry.cluster.TelemetryClusterInfoPeriodical] periodical in [0s], polling every [540s].
INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
INFO  [FailureSubmissionQueue] [FailureHandlerService#triggerShutdown] Total number of submitted batches: 0 (0 failures), total number of consumed batches: 0 (0 failures)
INFO  [FailureHandlingService] The service's thread has been interrupted. The queue currently contains 0 failure batches.
INFO  [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
INFO  [GracefulShutdownService] Running graceful shutdown for <1> shutdown hooks
INFO  [LogManager] Shutting down.
INFO  [GracefulShutdownService] Initiate shutdown for <JobWorkerPool>
INFO  [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
INFO  [JobSchedulerService] Shutdown of job heartbeat executor
INFO  [GracefulShutdownService] Finished shutdown for <JobWorkerPool>, took 1 ms
INFO  [LookupDataAdapterRefreshService] Stopping 0 jobs
INFO  [LogManager] Shutdown complete.
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.IndexBlockCheck].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
INFO  [Periodicals] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
INFO  [Periodicals] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Failed [LB:DEAD]
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.TrafficCounterCalculator].
INFO  [Periodicals] Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
ERROR [InputSetupService] Not starting any inputs because lifecycle is: Failed [LB:DEAD]
INFO  [Periodicals] Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
INFO  [Periodicals] Shutting down periodical [org.graylog2.periodical.ESVersionCheckPeriodical].
INFO  [Periodicals] Shutting down periodical [org.graylog2.telemetry.cluster.TelemetryClusterInfoPeriodical].
INFO  [Periodicals] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
INFO  [Periodicals] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
INFO  [Periodicals] Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
INFO  [Periodicals] Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
INFO  [Periodicals] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
INFO  [LocalKafkaMessageQueueReader] Stopping.
INFO  [Buffers] Waiting until [INPUT, PROCESS, OUTPUT] buffers are empty.
INFO  [Buffers] All buffers are empty. Continuing.
INFO  [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
INFO  [FailureHandlingService] Shutting down the service. Processed 0 remaining failure batches.
INFO  [FailureSubmissionQueue] [FailureHandlerService#shutDown] Total number of submitted batches: 0 (0 failures), total number of consumed batches: 0 (0 failures)
INFO  [ServiceManagerListener] Services are now stopped.
ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
java.lang.IllegalStateException: Expected to be healthy after starting. The following services are not running: {STARTING=[PeriodicalsService [STARTING]], FAILED=[JerseyService [FAILED]]}
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:769) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:581) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:295) ~[graylog.jar:?]
	at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:321) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:323) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:259) [graylog.jar:?]
	at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
	Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
	Caused by: java.lang.NoClassDefFoundError: org/graylog2/alerts/AlertService
		at java.lang.Class.getDeclaredConstructors0(Native Method) ~[?:?]
		at java.lang.Class.privateGetDeclaredConstructors(Unknown Source) ~[?:?]
		at java.lang.Class.getConstructors(Unknown Source) ~[?:?]
		at org.glassfish.jersey.server.model.MethodHandler$ClassBasedMethodHandler.<init>(MethodHandler.java:241) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.MethodHandler.create(MethodHandler.java:131) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.ResourceMethod$Builder.createInvocable(ResourceMethod.java:536) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.ResourceMethod$Builder.build(ResourceMethod.java:522) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.Resource$Builder.processMethodBuilders(Resource.java:647) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.Resource$Builder.buildResourceData(Resource.java:583) ~[graylog.jar:?]
		at org.glassfish.jersey.server.model.Resource$Builder.build(Resource.java:639) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.lambda$prefixResources$1(JerseyService.java:228) ~[graylog.jar:?]
		at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source) ~[?:?]
		at java.util.Spliterators$ArraySpliterator.forEachRemaining(Unknown Source) ~[?:?]
		at java.util.stream.AbstractPipeline.copyInto(Unknown Source) ~[?:?]
		at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source) ~[?:?]
		at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source) ~[?:?]
		at java.util.stream.AbstractPipeline.evaluate(Unknown Source) ~[?:?]
		at java.util.stream.ReferencePipeline.collect(Unknown Source) ~[?:?]
		at org.graylog2.shared.initializers.JerseyService.prefixResources(JerseyService.java:230) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.lambda$prefixPluginResources$0(JerseyService.java:210) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.prefixPluginResources(JerseyService.java:212) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:173) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:157) ~[graylog.jar:?]
		at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
		at com.google.common.util.concurrent.Callables$4.run(Callables.java:121) ~[graylog.jar:?]
		at java.lang.Thread.run(Unknown Source) ~[?:?]
	Caused by: java.lang.ClassNotFoundException: org.graylog2.alerts.AlertService
		at java.net.URLClassLoader.findClass(Unknown Source) ~[?:?]
		at java.lang.ClassLoader.loadClass(Unknown Source) ~[?:?]
		at java.net.FactoryURLClassLoader.loadClass(Unknown Source) ~[?:?]
INFO  [Server] SIGNAL received. Shutting down.
INFO  [GracefulShutdown] Graceful shutdown initiated.
INFO  [GracefulShutdown] Node status: [Override lb:DEAD [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
INFO  [GracefulShutdown] Goodbye.
Upgrade Opensearch 1.3.2 to 2.5.0 => log OK
Up^grade Mongod 4.2 to 4.4 to 5.0.22 to 6.0.9 =>log OK
Upgrade Graylog latest v4 to v5.1.4
I reccomend grabbing a clean copy of the latest configuration file via https://github.com/Graylog2/graylog2-server/blob/master/misc/graylog.conf and filling in your info.
One quick thing that sticks out to me though is you have a domain name configured for http_bind_address which is for an IP address and port only (commonly 0.0.0.0:9000)
http_publish_uri is where you configure the hostname to reach graylog
No change, i got always the error
is_leader = true
password_secret =
root_username = admin
http_bind_address = IP_ADRESS:9000
http_publish_uri = http://IP_ADRESS:9000/
elasticsearch_hosts = http://IP_ADRESS:9200
ring_size = 65536
INFO  [client] MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.8.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.10.0-24-amd64"}, "platform": "Java/Eclipse Adoptium/17.0.8+7"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@312b34e3]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=17508349}
INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1422873}
INFO  [DbEntitiesScanner] 16 entities have been scanned and added to DB Entity Catalog, it took 932.7 ms
INFO  [GracefulShutdownService] Finished shutdown for <JobWorkerPool>, took 2 ms
Looking closer it appears to be caused by this error java.lang.NoClassDefFoundError: org/graylog2/alerts/AlertService
which prompted me to think this is being caused by 3rd party plugins.
I do see you have the following installed:
  • Aggregation Count Alert Condition 2.2.0 [com.airbus-cyber-security.graylog.AggregationCountPlugin]
  • Alert Wizard 3.3.0 [com.airbus-cyber-security.graylog.AlertWizardPlugin]
  • Correlation Count Alert Condition 2.2.0 [com.airbus-cyber-security.graylog.CorrelationCountPlugin]
  • Logging Alert Notification 2.2.0 [com.airbus-cyber-security.graylog.LoggingAlertPlugin]
can you disable those and see if graylog-server starts successfully? If it does you can try enabling them one by one to see which trigger the error.
Just did a quick review of the 4 and i would get it is this one causing it: Aggregation Count Alert Condition 2.2.0 [com.airbus-cyber-security.graylog.AggregationCountPlugin]
Reading the readme via GitHub - airbus-cyber/graylog-plugin-aggregation-count: Alert condition plugin for Graylog to perform aggregation indicates the plugin is no longer supported and the functionality it provided has been added natively into graylog.
Thank you Drew, i delete graylog-plugin-aggregation-count-2.2.0.jar on my plugin’s folder and now is fine, Graylog is started.
