Graylog does not start after upgrade to 4.3
I upgraded Graylog to version 4.3 using yum on my Centos 7 server. However, after upgrade the server did not start and I found the following message from “/var/log/graylog-server/server.log”:
2022-05-30T20:14:57.326+03:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-05-30T20:14:59.717+03:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.3.0 [org.graylog.aws.AWSPlugin]
2022-05-30T20:14:59.718+03:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.3.0 [org.graylog.plugins.collector.CollectorPlugin]
2022-05-30T20:14:59.720+03:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.3.0 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-05-30T20:14:59.720+03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.3.0+7c09aad [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-05-30T20:14:59.720+03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.3.0+7c09aad [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-05-30T20:14:59.820+03:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2022-05-30T20:15:01.689+03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-05-30T20:15:01.850+03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-05-30T20:15:01.967+03:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:389}] to localhost:27017
2022-05-30T20:15:01.987+03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=17597790}
2022-05-30T20:15:02.077+03:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:390}] to localhost:27017
2022-05-30T20:15:02.175+03:00 INFO  [connection] Closed connection [connectionId{localValue:2, serverValue:390}] to localhost:27017 because the pool has been closed.
2022-05-30T20:15:02.178+03:00 INFO  [MongoDBPreflightCheck] Connected to MongoDB version 4.0.28
2022-05-30T20:15:02.707+03:00 INFO  [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <Elasticsearch:6.8.12>
2022-05-30T20:15:03.305+03:00 INFO  [Version] HV000001: Hibernate Validator null
2022-05-30T20:15:13.178+03:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-05-30T20:15:13.265+03:00 INFO  [NodeId] Node ID: 8eab9e8e-2e3e-4409-8ee5-06609758fe11
2022-05-30T20:15:13.998+03:00 INFO  [LogManager] Loading logs.
2022-05-30T20:15:14.101+03:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000004392243507.index, deleting and rebuilding index...
2022-05-30T20:15:19.815+03:00 INFO  [LogManager] Logs loading complete.
2022-05-30T20:15:19.821+03:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-05-30T20:15:19.845+03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-05-30T20:15:19.859+03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-05-30T20:15:19.869+03:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:391}] to localhost:27017
2022-05-30T20:15:19.871+03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1095149}
2022-05-30T20:15:19.887+03:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:392}] to localhost:27017
2022-05-30T20:15:20.303+03:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-05-30T20:15:21.511+03:00 INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running Elasticsearch:6.8.12
2022-05-30T20:15:21.673+03:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2022-05-30T20:15:21.674+03:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2022-05-30T20:15:21.931+03:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2022-05-30T20:15:21.931+03:00 INFO  [JestClientFactory] Node Discovery disabled...
2022-05-30T20:15:21.931+03:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2022-05-30T20:15:22.605+03:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:393}] to localhost:27017
2022-05-30T20:15:23.734+03:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-05-30T20:15:24.865+03:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-05-30T20:15:27.751+03:00 INFO  [ServerBootstrap] Graylog server 4.3.0+7c09aad starting up
2022-05-30T20:15:27.752+03:00 INFO  [ServerBootstrap] JRE: Red Hat, Inc. 1.8.0_332 on Linux 3.10.0-1127.19.1.el7.x86_64
2022-05-30T20:15:27.752+03:00 INFO  [ServerBootstrap] Deployment: rpm
2022-05-30T20:15:27.752+03:00 INFO  [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2022-05-30T20:15:27.752+03:00 INFO  [ServerBootstrap] Arch: amd64
2022-05-30T20:15:28.347+03:00 INFO  [ServerBootstrap] Running 44 migrations...
2022-05-30T20:15:30.891+03:00 WARN  [ServerBootstrap] Exception while running migrations
java.lang.RuntimeException: Could not resolve new ref for condition on EventDefinition <5e2afd8f39b22502c984949e>. oldref <"161a79ec-6d31-4317-94db-5cb214b272aa"> refMap <{6a294191-44fa-4990-8a30-b01384324d9b=count-}>
        at org.graylog2.migrations.V20200102140000_UnifyEventSeriesId.convertConditions(V20200102140000_UnifyEventSeriesId.java:116) ~[graylog.jar:?]
        at org.graylog2.migrations.V20200102140000_UnifyEventSeriesId.lambda$convertConditions$1(V20200102140000_UnifyEventSeriesId.java:127) ~[graylog.jar:?]
        at java.util.Iterator.forEachRemaining(Iterator.java:116) ~[?:1.8.0_332]
        at org.graylog2.migrations.V20200102140000_UnifyEventSeriesId.convertConditions(V20200102140000_UnifyEventSeriesId.java:124) ~[graylog.jar:?]
        at org.graylog2.migrations.V20200102140000_UnifyEventSeriesId.unifySeriesId(V20200102140000_UnifyEventSeriesId.java:103) ~[graylog.jar:?]
        at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:1.8.0_332]
        at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801) ~[?:1.8.0_332]
        at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_332]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_332]
        at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_332]
        at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_332]
        at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566) ~[?:1.8.0_332]
        at org.graylog2.migrations.V20200102140000_UnifyEventSeriesId.upgrade(V20200102140000_UnifyEventSeriesId.java:72) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.lambda$runMigrations$0(ServerBootstrap.java:263) ~[graylog.jar:?]
        at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422) ~[graylog.jar:?]
        at com.google.common.collect.RegularImmutableSortedSet.forEach(RegularImmutableSortedSet.java:88) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.runMigrations(ServerBootstrap.java:261) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:187) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:311) [graylog.jar:?]
        at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
Is there a way to manually handle that ref for condition on EventDefinition, or a configuration option that lets you omit that check? How should I start fixing this?
Thanks in advance for any help you can offer!
You may need to redo that Event Definition. Depend on what version you upgrade from. condition may have changed.
Thank you for the quick reply!
Is there an “offline” method of redoing/deleting an event? The server doesn’t start, so I’m unable to access the web UI.
I upgraded from the latest version, I think it was 4.2.9.
My apologies, I over looked the statement about Graylog service not starting, I was assuming you were able to get it running.
Couple tips you can look at.
  1. Insure that the Plugin directory has the correct version corresponding to the version of Graylog 4.2.9. that was installed.
  2. If using certificates double check those and the permissions of file and folders that Graylog uses.
  3. Insure the other services are running without issues ( i.e. Elasticsearch, MongoDb). You may want to check out there logs incase you might fine more clues on what’s going on.
Not that I know of.
We can help you further but need more info. The first would be is the full log file , if possible after starting graylog service. This would be done by tailing -f Graylogs log file. It will show a clear understanding how Graylog is starting up which gives a better idea how to troubleshoot this issue.
Next, post Graylog configuration file here to see if there were any missed configurations. If you could brief us on how you upgraded this server from version .x.x.x to y.y.y would be helpful from what I read Im not sure what is installed now or what version you started off with. When posting Configuration files or logs please use the markdown </>. I did adjust you log file post above, it was hard to read/understand.
By chance is there any configuration made outside Graylog Default configurations? Meaning do you have a custom made Index template, etc…
Thanks for the response.
I checked the plugin directory and it had the following files:
graylog-storage-elasticsearch7-4.3.0.jar
graylog-storage-elasticsearch6-4.3.0.jar
graylog-plugin-threatintel-4.3.0.jar
graylog-plugin-collector-4.3.0.jar
graylog-plugin-aws-4.3.0.jar
Based on this the plugin directory would correspond to version 4.3.0?
I double checked the configuration regarding certificates, and they are not being used. I should really enable https, but first I’ll need to fix the server.
I checked MongoDB service and it’s active without any problems. Elasticsearch is the same, it has been running non stop for one year and 7 months.
I’ll paste the output of logfiles at the end of this post. Lets see if they offer any usefull information (Elasticsearch hasn’t been creating new log files):
/var/log/mongodb/mongod.log
2022-06-13T11:05:13.854+0300 I NETWORK  [listener] connection accepted from 127.0.0.1:54836 #129180 (1 connection now open)
2022-06-13T11:05:13.894+0300 I NETWORK  [conn129180] received client metadata from 127.0.0.1:54836 conn129180: { driver: { name: "mongo-java-driver|legacy", version: "3.12.1" }, os: { type: "Linux", name: "Linux", architecture: "amd64", version: "3.10.0-1127.19.1.el7.x86_64" }, platform: "Java/Red Hat, Inc./1.8.0_332-b09" }
2022-06-13T11:05:14.017+0300 I NETWORK  [listener] connection accepted from 127.0.0.1:54838 #129181 (2 connections now open)
2022-06-13T11:05:14.028+0300 I NETWORK  [conn129181] received client metadata from 127.0.0.1:54838 conn129181: { driver: { name: "mongo-java-driver|legacy", version: "3.12.1" }, os: { type: "Linux", name: "Linux", architecture: "amd64", version: "3.10.0-1127.19.1.el7.x86_64" }, platform: "Java/Red Hat, Inc./1.8.0_332-b09" }
2022-06-13T11:05:14.178+0300 I NETWORK  [conn129180] end connection 127.0.0.1:54836 (1 connection now open)
2022-06-13T11:05:14.178+0300 I NETWORK  [conn129181] end connection 127.0.0.1:54838 (0 connections now open)
2022-06-13T11:05:31.442+0300 I NETWORK  [listener] connection accepted from 127.0.0.1:54842 #129182 (1 connection now open)
2022-06-13T11:05:31.457+0300 I NETWORK  [conn129182] received client metadata from 127.0.0.1:54842 conn129182: { driver: { name: "mongo-java-driver|legacy", version: "3.12.1" }, os: { type: "Linux", name: "Linux", architecture: "amd64", version: "3.10.0-1127.19.1.el7.x86_64" }, platform: "Java/Red Hat, Inc./1.8.0_332-b09" }
2022-06-13T11:05:31.473+0300 I NETWORK  [listener] connection accepted from 127.0.0.1:54844 #129183 (2 connections now open)
2022-06-13T11:05:31.486+0300 I NETWORK  [conn129183] received client metadata from 127.0.0.1:54844 conn129183: { driver: { name: "mongo-java-driver|legacy", version: "3.12.1" }, os: { type: "Linux", name: "Linux", architecture: "amd64", version: "3.10.0-1127.19.1.el7.x86_64" }, platform: "Java/Red Hat, Inc./1.8.0_332-b09" }
2022-06-13T11:05:35.403+0300 I NETWORK  [listener] connection accepted from 127.0.0.1:54848 #129184 (3 connections now open)
2022-06-13T11:05:35.441+0300 I NETWORK  [conn129184] received client metadata from 127.0.0.1:54848 conn129184: { driver: { name: "mongo-java-driver|legacy", version: "3.12.1" }, os: { type: "Linux", name: "Linux", architecture: "amd64", version: "3.10.0-1127.19.1.el7.x86_64" }, platform: "Java/Red Hat, Inc./1.8.0_332-b09" }
2022-06-13T11:05:42.415+0300 I NETWORK  [conn129182] end connection 127.0.0.1:54842 (2 connections now open)
2022-06-13T11:05:42.415+0300 I NETWORK  [conn129183] end connection 127.0.0.1:54844 (1 connection now open)
2022-06-13T11:05:42.415+0300 I NETWORK  [conn129184] end connection 127.0.0.1:54848 (0 connections now open
gc log (/var/log/elasticsearch/gc.log.10.current) keeps randomly pushing out following messages the timing of which don’t coincide with trying to start graylog server:
2022-06-13T11:17:02.849+0300: 52518225,967: Total time for which application threads were stopped: 0,0145317 seconds, Stopping threads took: 0,0001303 seconds
2022-06-13T11:21:57.947+0300: 52518521,065: [GC (Allocation Failure) 2022-06-13T11:21:57.947+0300: 52518521,065: [ParNew
Desired survivor size 4358144 bytes, new threshold 6 (max 6)
- age   1:     337992 bytes,     337992 total
- age   2:       5440 bytes,     343432 total
- age   3:        408 bytes,     343840 total
- age   4:        704 bytes,     344544 total
- age   5:         32 bytes,     344576 total
- age   6:        224 bytes,     344800 total
: 68489K->436K(76672K), 0,0140126 secs] 582844K->514791K(1040064K), 0,0142258 secs] [Times: user=0,02 sys=0,00, real=0,01 secs]
And here is everything that happens in /var/log/graylog-server/server.log after trying to start the server:
[root@localhost ~]# tail -f -n0 /var/log/graylog-server/server.log
2022-06-13T11:05:09.732+03:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-06-13T11:05:12.117+03:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.3.0 [org.graylog.aws.AWSPlugin]
2022-06-13T11:05:12.119+03:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.3.0 [org.graylog.plugins.collector.CollectorPlugin]
2022-06-13T11:05:12.133+03:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.3.0 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-06-13T11:05:12.134+03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.3.0+7c09aad [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-06-13T11:05:12.134+03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.3.0+7c09aad [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-06-13T11:05:12.213+03:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2022-06-13T11:05:13.746+03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-06-13T11:05:13.860+03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-06-13T11:05:13.945+03:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:129180}] to localhost:27017
2022-06-13T11:05:13.965+03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=17544223}
2022-06-13T11:05:14.061+03:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:129181}] to localhost:27017
2022-06-13T11:05:14.171+03:00 INFO  [connection] Closed connection [connectionId{localValue:2, serverValue:129181}] to localhost:27017 because the pool has been closed.
2022-06-13T11:05:14.173+03:00 INFO  [MongoDBPreflightCheck] Connected to MongoDB version 4.0.28
2022-06-13T11:05:14.695+03:00 INFO  [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <Elasticsearch:6.8.12>
2022-06-13T11:05:15.351+03:00 INFO  [Version] HV000001: Hibernate Validator null
2022-06-13T11:05:25.441+03:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-06-13T11:05:25.529+03:00 INFO  [NodeId] Node ID: 8eab9e8e-2e3e-4409-8ee5-06609758fe11
2022-06-13T11:05:26.312+03:00 INFO  [LogManager] Loading logs.
2022-06-13T11:05:26.406+03:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000004392243507.index, deleting and rebuilding index...
2022-06-13T11:05:31.404+03:00 INFO  [LogManager] Logs loading complete.
2022-06-13T11:05:31.410+03:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-06-13T11:05:31.438+03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-06-13T11:05:31.443+03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-06-13T11:05:31.463+03:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:129182}] to localhost:27017
2022-06-13T11:05:31.470+03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=6757153}
2022-06-13T11:05:31.502+03:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:129183}] to localhost:27017
2022-06-13T11:05:32.080+03:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-06-13T11:05:33.194+03:00 INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running Elasticsearch:6.8.12
2022-06-13T11:05:33.319+03:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2022-06-13T11:05:33.320+03:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2022-06-13T11:05:33.556+03:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2022-06-13T11:05:33.557+03:00 INFO  [JestClientFactory] Node Discovery disabled...
2022-06-13T11:05:33.557+03:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2022-06-13T11:05:35.255+03:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-06-13T11:05:35.458+03:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:129184}] to localhost:27017
2022-06-13T11:05:36.278+03:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-06-13T11:05:39.163+03:00 INFO  [ServerBootstrap] Graylog server 4.3.0+7c09aad starting up
2022-06-13T11:05:39.192+03:00 INFO  [ServerBootstrap] JRE: Red Hat, Inc. 1.8.0_332 on Linux 3.10.0-1127.19.1.el7.x86_64
2022-06-13T11:05:39.193+03:00 INFO  [ServerBootstrap] Deployment: rpm
2022-06-13T11:05:39.193+03:00 INFO  [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2022-06-13T11:05:39.193+03:00 INFO  [ServerBootstrap] Arch: amd64
2022-06-13T11:05:39.757+03:00 INFO  [ServerBootstrap] Running 44 migrations...
2022-06-13T11:05:42.138+03:00 WARN  [ServerBootstrap] Exception while running migrations
I hope tis information is of any help trying to solve the problem. I thank you for the time you’re taking to assist me on this!
I see you have connection to MongoDb localhost:27017, Also see a connection to Elasticsearch 127.0.0.1:9200.
What I’m not able to see is the end of the log file stating running, shutdown or failed. Normally there is a reason why.
The warn in GrayLog logs just shows Event definition problem.
What does Graylog status look like?
systemctl status graylog-server
What does Graylog configuration look like?
EDIT: Correction Graylog it shows this.
So it looks like Graylog started up?
And a closer look I seen this
Looks like you have some journal corruption but it also looks like it took care of that , I assume.
Here is the output of printing the graylog-server status:
   Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vend        or preset: disabled)
   Active: inactive (dead) (Result: exit-code) since ma 2022-06-13 11:05:42 EEST        ; 1 day 5h ago
     Docs: http://docs.graylog.org/
  Process: 18505 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=ex        ited, status=1/FAILURE)
 Main PID: 18505 (code=exited, status=1/FAILURE)
kesä 13 11:05:42 localhost.localdomain systemd[1]: graylog-server.service: m...
kesä 13 11:05:42 localhost.localdomain systemd[1]: Unit graylog-server.servi...
kesä 13 11:05:42 localhost.localdomain systemd[1]: graylog-server.service fa...
kesä 13 11:05:42 localhost.localdomain systemd[1]: Stopped Graylog server.
Hint: Some lines were ellipsized, use -l to show in full.
[root@localhost ~]# systemctl status graylog-server
   Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: disabled)
   Active: inactive (dead) (Result: exit-code) since ma 2022-06-13 11:05:42 EEST; 1 day 5h ago
  Process: 18505 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=exited, status=1/FAILURE)
kesä 13 11:05:42 localhost.localdomain systemd[1]: graylog-server.service: main process exited, code=exited, status=1/FAILURE
kesä 13 11:05:42 localhost.localdomain systemd[1]: Unit graylog-server.service entered failed state.
kesä 13 11:05:42 localhost.localdomain systemd[1]: graylog-server.service failed.
Here is some output from
journalctl --unit=graylog-server
kesä 13 11:05:06 localhost.localdomain systemd[1]: Started Graylog server.
kesä 13 11:05:06 localhost.localdomain graylog-server[18505]: OpenJDK 64-Bit Server VM warning: If the number of processors is expected to increase from one, then you should configure the number of parallel GC threads appropriately using -XX:ParallelGCThreads=N
Actually it seems like the server is unable to “fix” the journal corruption because every time the server tries to start that line is present. I did try to disable the journal though and it didn’t seem to help setting:
message_journal_enabled = false
I’ll post the server configuration in separate message.
Here are the contents of server.conf file:
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = SKejsdfgNKB1203*Ä*FLErjmbn230483i1KGDSNvcxxxxxxxxxxxxxxxxxxxxx
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = 932b33b2de4f8f1a9fb326d5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# Default is empty
root_email = "xxxxxx@xxx.xx"
# Default is UTC
root_timezone = Europe/Helsinki
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# Default: data
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 192.168.xxx.xxx:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 16
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
message_journal_max_size = 4gb
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Email transport
transport_email_hostname = smtp.gmail.com
transport_email_port = 587
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username = xxxxxxxxx@xxx.xx
transport_email_auth_password = xxxxxxxxxxxx
transport_email_from_email = xxxxxxxxx@xxx.xx
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = true
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
```root
I scanned over you configuration file. I didn’t see anything sticking out that could be the issue. To be honest, It looks like default settings. Did noticed that journal was reconfigured. The version of elasticsearch & Mongo seam to be within parameters.
As for this error
I found something similar here
Couple ideas.
If you don’t mind losing data you could delete everything in the journal then restart Graylog service.
You can find which file here
So it seams there is nothing in Graylog log file after i service stops.
Perhaps some simple checks:
Look over this site, see if anything does pertain to your environment.
Somethings have changed.
Check permissions on Graylog Directory.
The server won’t start up if it hits an unexpected exception during migrations.
Your log shows there is an inconsistency in event definitions, which is causing the exception.
To resolve it you can delete the offending event definition 5e2afd8f39b22502c984949e in the MongoDB and then recreate it later via UI, if needed.
Thank you patrickmann, that solved my problem. I logged into mongodb and deleted the event definition in question. After that I tailed the log and got a nasty looking error because the event in question did not exist anymore, but the server started despite that.
I’ll post the offending event information here just in case there is something obviously wrong with that, which could help with debugging in possible similar future cases:
{ "_id" : ObjectId("5e2afd8f39b22502c984949e"), "title" : "VehkaIrisHälytys", "description" : "", "priority" : 2, "alert" : true, "config" : { "type" : "aggregation-v1", "query" : "", "streams" : [ "5e2afafa39b22502c9848ec9" ], "group_by" : [ ], "series" : [ { "id" : "6a294191-44fa-4990-8a30-b01384324d9b", "function" : "count", "field" : null } ], "conditions" : { "expression" : { "expr" : "==", "left" : { "expr" : "number-ref", "ref" : "161a79ec-6d31-4317-94db-5cb214b272aa" }, "right" : { "expr" : "number", "value" : 0 } } }, "search_within_ms" : NumberLong(300000), "execute_every_ms" : NumberLong(300000) }, "field_spec" : {  }, "key_spec" : [ ], "notification_settings" : { "grace_period_ms" : NumberLong(300000), "backlog_size" : NumberLong(0) }, "notifications" : [ { "notification_id" : "5e2afd3c39b22502c98493c2", "notification_parameters" : null } ], "storage" : [ { "type" : "persist-to-streams-v1", "streams" : [ "000000000000000000000002" ] } ] }
Can you post the mongo commands you used to find and delete the even definition? That will help future searchers! :smiley:
I used these commands to delete the event:
[root@localhost ~]# mongo
> use graylog
> db.event_definitions.deleteOne({_id:ObjectId("5e2afd8f39b22502c984949e")})
You’ll need to use the id found in the log file for ObjectId({}) to delete it.
