Graylog won't start after install
I’ve installed Graylog on a new server by following the official documentation but the server won’t start and keeps restarting. Here is what I have in “/var/log/graylog-server/server.log”:
2017-06-22T01:42:50.867+02:00 INFO [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-22T01:42:50.869+02:00 INFO [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-22T01:42:50.869+02:00 INFO [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-22T01:42:50.870+02:00 INFO [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-22T01:42:50.876+02:00 INFO [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-22T01:42:50.876+02:00 INFO [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-22T01:42:51.051+02:00 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2017-06-22T01:42:51.196+02:00 INFO [Version] HV000001: Hibernate Validator null
2017-06-22T01:42:52.777+02:00 INFO [InputBufferImpl] Message journal is enabled.
2017-06-22T01:42:52.794+02:00 INFO [NodeId] Node ID: 111d6cea-ea1e-4e86-b71e-ec4d28af98a1
2017-06-22T01:42:53.002+02:00 INFO [LogManager] Loading logs.
2017-06-22T01:42:53.039+02:00 INFO [LogManager] Logs loading complete.
2017-06-22T01:42:53.039+02:00 INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2017-06-22T01:42:53.051+02:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2017-06-22T01:42:53.070+02:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2017-06-22T01:42:53.102+02:00 INFO [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2017-06-22T01:42:53.122+02:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:436}] to localhost:27017
2017-06-22T01:42:53.124+02:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 2, 14]}, minWireVersion=0, maxWireVersion=4, maxDocumentSize=16777216, roundTripTimeNanos=560906}
2017-06-22T01:42:53.129+02:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:437}] to localhost:27017
2017-06-22T01:42:53.347+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] version[2.4.4], pid[11359], build[fcbb46d/2017-01-03T11:33:16Z]
2017-06-22T01:42:53.347+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] initializing …
2017-06-22T01:42:53.352+02:00 INFO [plugins] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] modules [], plugins [graylog-monitor], sites []
2017-06-22T01:42:54.384+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] initialized
2017-06-22T01:42:54.431+02:00 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2017-06-22T01:42:55.497+02:00 INFO [RulesEngineProvider] No static rules file loaded.
2017-06-22T01:42:55.666+02:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-22T01:42:55.670+02:00 INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy .
2017-06-22T01:42:55.708+02:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-22T01:42:55.746+02:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-22T01:42:55.779+02:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-22T01:42:55.810+02:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-22T01:42:56.309+02:00 INFO [ServerBootstrap] Graylog server 2.2.3+7adc951 starting up
2017-06-22T01:42:56.309+02:00 INFO [ServerBootstrap] JRE: Oracle Corporation 1.8.0_131 on Linux 3.10.0-514.21.2.el7.x86_64
2017-06-22T01:42:56.309+02:00 INFO [ServerBootstrap] Deployment: rpm
2017-06-22T01:42:56.309+02:00 INFO [ServerBootstrap] OS: ()
2017-06-22T01:42:56.310+02:00 INFO [ServerBootstrap] Arch: amd64
2017-06-22T01:42:56.312+02:00 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-06-22T01:42:56.326+02:00 INFO [PeriodicalsService] Starting 26 periodicals …
2017-06-22T01:42:56.326+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2017-06-22T01:42:56.326+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2017-06-22T01:42:56.327+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2017-06-22T01:42:56.330+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2017-06-22T01:42:56.330+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] starting …
2017-06-22T01:42:56.332+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical, running forever.
2017-06-22T01:42:56.336+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2017-06-22T01:42:56.337+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2017-06-22T01:42:56.337+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2017-06-22T01:42:56.337+02:00 INFO [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2017-06-22T01:42:56.338+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2017-06-22T01:42:56.338+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2017-06-22T01:42:56.339+02:00 INFO [connection] Opened connection [connectionId{localValue:3, serverValue:438}] to localhost:27017
2017-06-22T01:42:56.340+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2017-06-22T01:42:56.341+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2017-06-22T01:42:56.341+02:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2017-06-22T01:42:56.341+02:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2017-06-22T01:42:56.341+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2017-06-22T01:42:56.342+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2017-06-22T01:42:56.342+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2017-06-22T01:42:56.346+02:00 INFO [connection] Opened connection [connectionId{localValue:4, serverValue:439}] to localhost:27017
2017-06-22T01:42:56.347+02:00 INFO [connection] Opened connection [connectionId{localValue:5, serverValue:440}] to localhost:27017
2017-06-22T01:42:56.347+02:00 INFO [connection] Opened connection [connectionId{localValue:6, serverValue:441}] to localhost:27017
2017-06-22T01:42:56.349+02:00 INFO [connection] Opened connection [connectionId{localValue:7, serverValue:442}] to localhost:27017
2017-06-22T01:42:56.351+02:00 INFO [connection] Opened connection [connectionId{localValue:8, serverValue:443}] to localhost:27017
2017-06-22T01:42:56.353+02:00 INFO [connection] Opened connection [connectionId{localValue:9, serverValue:444}] to localhost:27017
2017-06-22T01:42:56.374+02:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2017-06-22T01:42:56.374+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2017-06-22T01:42:56.374+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2017-06-22T01:42:56.375+02:00 INFO [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2017-06-22T01:42:56.378+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2017-06-22T01:42:56.379+02:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2017-06-22T01:42:56.379+02:00 INFO [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] periodical in [300s], polling every [21600s].
2017-06-22T01:42:56.380+02:00 INFO [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] periodical in [300s], polling every [21600s].
2017-06-22T01:42:56.381+02:00 INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2017-06-22T01:42:56.382+02:00 INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2017-06-22T01:42:56.387+02:00 INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2017-06-22T01:42:56.436+02:00 INFO [transport] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] publish_address {127.0.0.1:9350}, bound_addresses {[::1]:9350}, {127.0.0.1:9350}
2017-06-22T01:42:56.442+02:00 INFO [discovery] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] graylog/LBQHrHrJTJKlpGeU26dnJA
2017-06-22T01:42:56.447+02:00 INFO [V20161130141500_DefaultStreamRecalcIndexRanges] Cluster not connected yet, delaying migration until it is reachable.
2017-06-22T01:42:56.710+02:00 ERROR [ServiceManager] Service JerseyService [FAILED] has failed in the STARTING state.
java.net.URISyntaxException: Expected scheme-specific part at index 5: http:
at java.net.URI$Parser.fail(Unknown Source) ~[?:1.8.0_131]
at java.net.URI$Parser.failExpecting(Unknown Source) ~[?:1.8.0_131]
at java.net.URI$Parser.parse(Unknown Source) ~[?:1.8.0_131]
at java.net.URI.(Unknown Source) ~[?:1.8.0_131]
at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:216) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:139) ~[graylog.jar:?]
at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) [graylog.jar:?]
at com.google.common.util.concurrent.Callables$4.run(Callables.java:122) [graylog.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_131]
2017-06-22T01:42:56.714+02:00 ERROR [InputSetupService] Not starting any inputs because lifecycle is: Uninitialized [LB:DEAD]
2017-06-22T01:42:56.717+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.AlertScannerThread].
2017-06-22T01:42:56.718+02:00 WARN [BufferSynchronizerService] Elasticsearch is unavailable. Not waiting to clear buffers and caches, as we have no healthy cluster.
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.AlertScannerThread] complete, took <0ms>.
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
2017-06-22T01:42:56.718+02:00 INFO [LogManager] Shutting down.
2017-06-22T01:42:56.718+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] stopping …
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
2017-06-22T01:42:56.718+02:00 INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
2017-06-22T01:42:56.718+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.VersionCheckThread].
2017-06-22T01:42:56.720+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.VersionCheckThread] complete, took <0ms>.
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical].
2017-06-22T01:42:56.721+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] complete, took <0ms>.
2017-06-22T01:42:56.722+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical].
2017-06-22T01:42:56.722+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] complete, took <0ms>.
2017-06-22T01:42:56.722+02:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
2017-06-22T01:42:56.722+02:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
2017-06-22T01:42:56.731+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] stopped
2017-06-22T01:42:56.731+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] closing …
2017-06-22T01:42:56.734+02:00 INFO [node] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] closed
2017-06-22T01:42:56.781+02:00 INFO [LogManager] Shutdown complete.
2017-06-22T01:42:56.789+02:00 INFO [JournalReader] Stopping.
2017-06-22T01:42:59.445+02:00 WARN [discovery] [graylog-111d6cea-ea1e-4e86-b71e-ec4d28af98a1] waited for 3s and no initial state was set by the discovery
2017-06-22T01:42:59.445+02:00 ERROR [ServiceManager] Service IndexerSetupService [FAILED] has failed in the STOPPING state.
java.lang.IllegalStateException: Can’t move to started state when closed
at org.elasticsearch.common.component.Lifecycle.canMoveToStarted(Lifecycle.java:114) ~[graylog.jar:?]
at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:62) ~[graylog.jar:?]
at org.elasticsearch.node.Node.start(Node.java:291) ~[graylog.jar:?]
at org.graylog2.initializers.IndexerSetupService.startUp(IndexerSetupService.java:114) ~[graylog.jar:?]
2017-06-22T01:42:59.446+02:00 INFO [ServiceManagerListener] Services are now stopped.
2017-06-22T01:42:59.446+02:00 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-06-22T01:42:59.446+02:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
java.lang.IllegalStateException: Expected to be healthy after starting. The following services are not running: {STARTING=[IndexerSetupService [STARTING]], FAILED=[JerseyService [FAILED]]}
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:742) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:555) ~[graylog.jar:?]
at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:304) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:147) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:209) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:44) [graylog.jar:?]
2017-06-22T01:42:59.446+02:00 INFO [Server] SIGNAL received. Shutting down.
2017-06-22T01:42:59.450+02:00 INFO [GracefulShutdown] Graceful shutdown initiated.
2017-06-22T01:42:59.450+02:00 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-06-22T01:42:59.450+02:00 INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
2017-06-22T01:43:03.452+02:00 INFO [GracefulShutdown] Goodbye.
Any idea on how to fix that?
Thank you.
I’m not the most knowledgeable, but I’ll take a crack at it.
First, are you using the most current documentation? (I had issues once when I was using an older version’s doc’s)
Have you tried repeating the same steps in a local virtual machine (like VirtualBox or Docker container) to see if you get the same types of errors? (Might be worth trying)
Yes, I use the most recent documentation. I followed the instructions on this page: http://docs.graylog.org/en/2.2/pages/installation/os/centos.html
I installed it on a dedicated server. I will try a new install and see.
@bnabilos
it looks like your Graylog was:
  • not able to connect to elasticsearch
  • was not able to bind to the configured interface
next time please add your configuration and please use
TEXT
to make your entries with log files and configuration easier to read.
thank you
