Graylog Splunk Plugin 0.4.0 with Graylog 3.2.2 not working
I am using Graylog 3.2.2 (3 nodes cluster) and the Graylog Splunk Plugin 0.4.0 here: https://marketplace.graylog.org/addons/974efcc3-8d78-4847-becd-0f26821d2646
For the installation, I have copied the plugin on each of the graylog servers manually (was that correct or does the plugin get replicated automatically if copied to e.g. the master graylog server?).
I tried to configure the Splunk Plugin output to the all messages stream but got an error message at first. Unfortunately it disappeared to quickly. I retried the output assignment, then it worked but no effective output was generated.
Moreover, I had to restart the graylog servers because the message sync over the cluster was broken down.
Questions:
Is this plugin compatible with Graylog 3.2.2?
Is there a newer version than 0.4.0?
Is there any better way to forward messages from Graylog to Splunk?
Thanks and best regards,
Jan
he @janholzbecher
you can find the releases here: https://github.com/graylog-labs/graylog-plugin-splunk/releases
It might be that this plugin is not compatible with the latest Graylog release.
Hi Jan,
Thats exaclty the plugin I am using, however, not the RC version. Would you suggest using the RC?
Is there any alternative for a stream output to Splunk?
Best regards,
Jan
