Aggregates Plugin - Graylog 2.3.0-alpha.3+c795033
I’m using Graylog v2.3.0-alpha.3+c795033 but when I put that plugin on his directory and I restart the graylog-server doesn’t start. I can’t see any logs error, this is last lines:
2017-06-08T09:37:30.212+02:00 INFO [CmdLineTool] Loaded plugin: Aggregates 1.0.1 [org.graylog.plugins.aggregates.AggregatesPlugin]
2017-06-08T09:37:30.214+02:00 INFO [CmdLineTool] Loaded plugin: Elastic Beats Input 2.3.0-alpha.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-08T09:37:30.215+02:00 INFO [CmdLineTool] Loaded plugin: Collector 2.3.0-alpha.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-08T09:37:30.216+02:00 INFO [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.3.0-alpha.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-08T09:37:30.216+02:00 INFO [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.3.0-alpha.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-08T09:37:30.217+02:00 INFO [CmdLineTool] Loaded plugin: NetFlowPlugin 0.1.0 [org.graylog.plugins.netflow.NetFlowPlugin]
2017-06-08T09:37:30.224+02:00 INFO [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.3.0-alpha.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-08T09:37:30.225+02:00 INFO [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.3.0-alpha.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-08T09:37:30.225+02:00 INFO [CmdLineTool] Loaded plugin: SnmpPlugin 0.3.0 [org.graylog.snmp.SnmpPlugin]
2017-06-08T09:37:30.444+02:00 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackT
raceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2017-06-08T09:37:30.646+02:00 INFO [Version] HV000001: Hibernate Validator null
Any idea? Thanks.
did the plugin author said that this plugin works with 2.3?
Yes, He said: Required Graylog version: 2.0 and later
I am using latest stable.
@berekese 2.3 is not stable - it is alpha.
you should check if your Graylog is running without any third party plugin and after that add them one after another and careful check if everything is working.
Uhm, you r right :slight_smile:
I am only using netflow plugin (SNMP comes by default)
Without plugins, plugin Aggregate doesn’t work, same log all time:
2017-06-14T07:48:04.946+02:00 INFO  [CmdLineTool] Loaded plugin: Aggregates 1.0.1 [org.graylog.plugins.aggregates.AggregatesPlugin]
2017-06-14T07:48:04.948+02:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.3.0-alpha.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-14T07:48:04.949+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.3.0-alpha.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-14T07:48:04.950+02:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.3.0-alpha.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-14T07:48:04.951+02:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.3.0-alpha.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-14T07:48:04.960+02:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.3.0-alpha.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-14T07:48:04.961+02:00 INFO  [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.3.0-alpha.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-14T07:48:05.184+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2017-06-14T07:48:05.377+02:00 INFO  [Version] HV000001: Hibernate Validator null
Plugins that are loaded are defaults plugins.
Any idea? Thanks.
What exactly does “doesn’t work” mean?
How have you checked that and what did you expect to happen?
If I copy plugin Aggregate to plugin directory, Graylog doesn’t start, port 9000 doesn’t running.
My last error keeping loading all time but doesn’t port.
Thanks.
Try posting a bug report with the original author of the plugin. Maybe it’s simply incompatible with your version of Graylog.
I did it one week ago but I hadn’t reply yet.
Thanks jochen.
