Graylog Retention Strategy Not Being Followed
Hi All,
I have set a Graylog instance to only hold 60 indices and delete all others. I had previously closed some older indices and then noticed that Graylog was not following the retention strategy and now has 69 indices, I then opened the old indices thinking that closing them may have caused this, but Graylog still hasn’t deleted them.
I have also tried cyling the active write index and recalculating index ranges, but this helped.
I encountered this issue once before, however I found Elasticsearch to be Red in status and resolving that issue resolved the retention strategy problem. In this case Elasticsearch is healthy.
System Specs
OS: Ubuntu 16.04 LTS
Graylog: 2.4.4
Elasticsearch: 5.6.9
MongoDB: 2.6.10
Here you can see my config and also the amount of incides in the system.
Regards,
G
did you see any entries in the logfiles about the retention check?
Graylog should give you some ideas why it can’t run the retention checks.
Hi Jan,
I looked in the logs and can’t find anything regarding retention strategies.
I have looked into another working system and found logs such as these:
2018-08-21T01:03:58.379+01:00 INFO  [AbstractIndexCountBasedRetentionStrategy] Number of indices (4) higher than limit (3). Running retention for 1 indices.
2018-08-21T01:03:59.296+01:00 INFO  [AbstractIndexCountBasedRetentionStrategy] Running retention strategy [org.graylog2.indexer.retention.strategies.DeletionRetentionStrategy] for index <graylog_381>
Both systems are configured the same, however the one that is not working is set to 60 indices instead of 4.
Cheers,
G
you need to find the difference to solve the issue.
The one that works is on 2.4.5 and the one that isn’t working is on 2.4.4, is this a known issue of 2.4.4?
We will aim to update as soon as we can but due to being in production it will have to be scheduled in.
not that I know - so it should be something else.
I did close and reopen about ten of the indices on the system that is not working properly. That’s all I can think of, it shouldn’t have caused this.
