Graylog Indices with problem
Good afternoon people
I set my Max number of indices = 20
Select retention strategy = Delete index
But, I already have 36 indices and it doesn’t stop increasing. Max number of indices is not running. I’m deleting the indexes manually.
Does anyone know what the problem is? It is consuming a lot of disk resource.
Thanks.
How are you deleting them, via the Graylog GUI? Have you tried recalculating the index ranges? (System->Indicies->click on the index, click on maintenance button…) Have you looked in your Graylog log files? Graylog will post in there when it makes retention adjustments and ought to post an error if it was failing.
You could rotate indices manually to get a reaction in the logs
Are there any health issues with Elasticsearch:
curl -XGET http://localhost:9200/_cat/indices?pretty
and/or:
curl -XGET http://localhost:9200/_cluster/allocation/explain?pretty
