Graylog-Ctl Scripts Missing
Hi there,
I installed (successfully) today from the 2.6 OVA on a VM. The documentation says the VM version should have Graylog-ctl script(s) built in, but I can’t find or invoke them. Can I add them separately?
the graylog-ctl script is part of the omnibus package - how did you installed the OVA?
Hi Jan,
I installed it using vSphere. I don’t think I was very peculiar about the options used to launch the VM but I don’t imagine any of them would cause the scripts to disappear anyways :stuck_out_tongue: Is there a way I can download them by themselves?
it is not a simple script - and it is part of the omnibus package ( https://github.com/Graylog2/omnibus-graylog2 ) that is the source of the OVA image.
What Image exactly did you use? What download source?
Oh, I see.
Sorry, I kept saying “2.6” by mistake but it’s actually
http://graylog2-releases.s3.amazonaws.com/graylog-omnibus/ova/graylog-2.4.6-1.ova[...]
where I got the install file.
From the https://packages.graylog2.org/appliances/ova site :slight_smile:
