I’m a new graylog users and have just deployed the ova in my vmware environment. I completed the configuration, opened a browser to the IP and was greeted with a message that graylog was restarting and to wait a couple minutes. I’ve done that, but the issue persists. Nothing in the logs and the services are all running. Any ideas?
Is there anything in the logs of Graylog or Elasticsearch at all?
http://docs.graylog.org/en/2.2/pages/configuration/file_location.html#omnibus-package
What’s the configuration of your virtual machine?
Which commands did you execute to configure the OVA and what was their output?
After the OVA booted up, I configured the network and ran the following commands from the documentation:
sudo apt-get install -y open-vm-tools
graylog-ctl set-email-config "my SMTP"
graylog-ctl set-admin-password "my password"
graylog-ctl set-timezone CST
graylog-ctl reconfigure
After the commands, I tried going to the web GUI and encountered the GRAYLOG is restarting issue. I’m sure I’m missing something…
If I go to /var/log/graylog/elasticsearch I see the following
-rw-r--r-- 1 root root 2508 Jun 27 15:59 @4000000059528110199daf94.u
-rw-r--r-- 1 root root 30 Jun 27 15:36 config
-rw-r--r-- 1 root root 2218 Jun 27 16:00 current
-rw------- 1 graylog graylog 0 Jun 27 15:36 graylog_deprecation.log
-rw------- 1 graylog graylog 0 Jun 27 15:36 graylog_index_indexing_slowlog.log
-rw------- 1 graylog graylog 0 Jun 27 15:36 graylog_index_search_slowlog.log
-rw------- 1 graylog graylog 5009 Jun 27 16:00 graylog.log
-rw------- 1 root root 0 Jun 27 15:36 lock
If I look at graylog.log, I see…
[2017-06-27 15:36:36,489][INFO ][node ] [Bela] version[2.4.2], pid[1882], build[161c65a/2016-11-17T11:51:03Z]
[2017-06-27 15:36:36,494][INFO ][node ] [Bela] initializing ...
[2017-06-27 15:36:40,697][INFO ][plugins ] [Bela] modules [reindex, lang-expression, lang-groovy], plugins [kopf], sites [kopf]
[2017-06-27 15:36:41,037][INFO ][env ] [Bela] using [1] data paths, mounts [[/ (/dev/mapper/graylog--vg-root)]], net usable_space [11.4gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2017-06-27 15:36:41,037][INFO ][env ] [Bela] heap size [2.3gb], compressed ordinary object pointers [true]
[2017-06-27 15:36:41,041][WARN ][env ] [Bela] max file descriptors [64000] for elasticsearch process likely too low, consider increasing to at least [65536]
[2017-06-27 15:36:47,860][INFO ][node ] [Savage Steel] version[2.4.2], pid[2085], build[161c65a/2016-11-17T11:51:03Z]
[2017-06-27 15:36:47,861][INFO ][node ] [Savage Steel] initializing ...
[2017-06-27 15:36:49,361][INFO ][plugins ] [Savage Steel] modules [reindex, lang-expression, lang-groovy], plugins [kopf], sites [kopf]
[2017-06-27 15:36:49,422][INFO ][env ] [Savage Steel] using [1] data paths, mounts [[/ (/dev/mapper/graylog--vg-root)]], net usable_space [11.4gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2017-06-27 15:36:49,432][INFO ][env ] [Savage Steel] heap size [2.3gb], compressed ordinary object pointers [true]
[2017-06-27 15:36:49,436][WARN ][env ] [Savage Steel] max file descriptors [64000] for elasticsearch process likely too low, consider increasing to at least [65536]
[2017-06-27 15:36:54,311][INFO ][node ] [Savage Steel] initialized
[2017-06-27 15:36:54,313][INFO ][node ] [Savage Steel] starting ...
[2017-06-27 15:36:54,524][INFO ][transport ] [Savage Steel] publish_address {10.240.1.120:9300}, bound_addresses {10.240.1.120:9300}
[2017-06-27 15:36:54,535][INFO ][discovery ] [Savage Steel] graylog/YN5lqdomQbGHlEirSlpCVA
[2017-06-27 15:37:04,596][INFO ][cluster.service ] [Savage Steel] new_master {Savage Steel}{YN5lqdomQbGHlEirSlpCVA}{10.240.1.120}{10.240.1.120:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
[2017-06-27 15:37:04,682][INFO ][http ] [Savage Steel] publish_address {10.240.1.120:9200}, bound_addresses {10.240.1.120:9200}
[2017-06-27 15:37:04,684][INFO ][node ] [Savage Steel] started
[2017-06-27 15:37:04,737][INFO ][gateway ] [Savage Steel] recovered [0] indices into cluster_state
[2017-06-27 15:59:45,545][INFO ][node ] [Savage Steel] stopping ...
[2017-06-27 15:59:45,604][INFO ][node ] [Savage Steel] stopped
[2017-06-27 15:59:45,604][INFO ][node ] [Savage Steel] closing ...
[2017-06-27 15:59:45,611][INFO ][node ] [Savage Steel] closed
[2017-06-27 16:00:17,470][INFO ][node ] [Tethlam] version[2.4.2], pid[826], build[161c65a/2016-11-17T11:51:03Z]
[2017-06-27 16:00:17,472][INFO ][node ] [Tethlam] initializing ...
[2017-06-27 16:00:19,180][INFO ][plugins ] [Tethlam] modules [reindex, lang-expression, lang-groovy], plugins [kopf], sites [kopf]
[2017-06-27 16:00:19,287][INFO ][env ] [Tethlam] using [1] data paths, mounts [[/ (/dev/mapper/graylog--vg-root)]], net usable_space [11.4gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2017-06-27 16:00:19,295][INFO ][env ] [Tethlam] heap size [2.3gb], compressed ordinary object pointers [true]
[2017-06-27 16:00:19,297][WARN ][env ] [Tethlam] max file descriptors [64000] for elasticsearch process likely too low, consider increasing to at least [65536]
[2017-06-27 16:00:25,339][INFO ][node ] [Tethlam] initialized
[2017-06-27 16:00:25,340][INFO ][node ] [Tethlam] starting ...
[2017-06-27 16:00:25,582][INFO ][transport ] [Tethlam] publish_address {10.240.1.120:9300}, bound_addresses {10.240.1.120:9300}
[2017-06-27 16:00:25,596][INFO ][discovery ] [Tethlam] graylog/M0JYvr0kSSWNMJXKP0rqfQ
[2017-06-27 16:00:35,661][INFO ][cluster.service ] [Tethlam] new_master {Tethlam}{M0JYvr0kSSWNMJXKP0rqfQ}{10.240.1.120}{10.240.1.120:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
[2017-06-27 16:00:35,712][INFO ][http ] [Tethlam] publish_address {10.240.1.120:9200}, bound_addresses {10.240.1.120:9200}
[2017-06-27 16:00:35,714][INFO ][node ] [Tethlam] started
[2017-06-27 16:00:35,740][INFO ][gateway ] [Tethlam] recovered [0] indices into cluster_state
Current shows the following…
2017-06-27_16:00:17.47114 [2017-06-27 16:00:17,470][INFO ][node ] [Tethlam] version[2.4.2], pid[826], build[161c65a/2016-11-17T11:51:03Z]
2017-06-27_16:00:17.47292 [2017-06-27 16:00:17,472][INFO ][node ] [Tethlam] initializing ...
2017-06-27_16:00:19.18049 [2017-06-27 16:00:19,180][INFO ][plugins ] [Tethlam] modules [reindex, lang-expression, lang-groovy], plugins [kopf], sites [kopf]
2017-06-27_16:00:19.28783 [2017-06-27 16:00:19,287][INFO ][env ] [Tethlam] using [1] data paths, mounts [[/ (/dev/mapper/graylog--vg-root)]], net usable_space [11.4gb], net total_space [14.9gb], spins? [possibly], types [ext4]
2017-06-27_16:00:19.29540 [2017-06-27 16:00:19,295][INFO ][env ] [Tethlam] heap size [2.3gb], compressed ordinary object pointers [true]
2017-06-27_16:00:19.29726 [2017-06-27 16:00:19,297][WARN ][env ] [Tethlam] max file descriptors [64000] for elasticsearch process likely too low, consider increasing to at least [65536]
2017-06-27_16:00:25.33986 [2017-06-27 16:00:25,339][INFO ][node ] [Tethlam] initialized
2017-06-27_16:00:25.34057 [2017-06-27 16:00:25,340][INFO ][node ] [Tethlam] starting ...
2017-06-27_16:00:25.58312 [2017-06-27 16:00:25,582][INFO ][transport ] [Tethlam] publish_address {10.240.1.120:9300}, bound_addresses {10.240.1.120:9300}
2017-06-27_16:00:25.59670 [2017-06-27 16:00:25,596][INFO ][discovery ] [Tethlam] graylog/M0JYvr0kSSWNMJXKP0rqfQ
2017-06-27_16:00:35.66148 [2017-06-27 16:00:35,661][INFO ][cluster.service ] [Tethlam] new_master {Tethlam}{M0JYvr0kSSWNMJXKP0rqfQ}{10.240.1.120}{10.240.1.120:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
2017-06-27_16:00:35.71247 [2017-06-27 16:00:35,712][INFO ][http ] [Tethlam] publish_address {10.240.1.120:9200}, bound_addresses {10.240.1.120:9200}
2017-06-27_16:00:35.71424 [2017-06-27 16:00:35,714][INFO ][node ] [Tethlam] started
2017-06-27_16:00:35.74020 [2017-06-27 16:00:35,740][INFO ][gateway ] [Tethlam] recovered [0] indices into cluster_state
What is/was the output of those commands?
These are the logs of Elasticsearch. What’s in the logs of Graylog?
When I ran the install command it went through a normal installation process. I don’t recall the output for the remaining commands. isn’t the location on the graylog logs /var/log/graylog-server? If so, that directory doesn’t exist. If not, where are the logs for graylog? Here’s the listing under /var/log/graylog.
ubuntu@graylog:/var/log$ cd /var/log/graylog
ubuntu@graylog:/var/log/graylog$ ls -l
total 20
drwx------ 2 graylog root 4096 Jun 28 16:00 elasticsearch
drwx------ 2 graylog root 4096 Jun 28 16:00 etcd
drwx------ 2 graylog root 4096 Jun 28 16:00 mongodb
drwx------ 2 root root 4096 Jun 28 16:00 nginx
drwx------ 2 graylog root 4096 Jun 28 16:00 server
Here’s what is repeating over and over in the log… it’s referencing timezone. Here’s the command I used to set the timezone: sudo graylog-ctl set-timezone America/Chicago, but when I run the date command it shows time is off by 5 hours.
2017-06-29_12:44:12.87077 It looks like you are trying to access MongoDB over HTTP on the native driver port.
2017-06-29_12:44:16.69130 2017-06-29 12:44:16,689 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-29_12:44:16.69310 2017-06-29 12:44:16,692 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-29_12:44:16.69514 2017-06-29 12:44:16,694 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-29_12:44:16.69700 2017-06-29 12:44:16,696 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-29_12:44:16.70923 2017-06-29 12:44:16,709 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-29_12:44:16.71155 2017-06-29 12:44:16,711 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-29_12:44:16.73624 2017-06-29 12:44:16,732 ERROR: org.graylog2.bootstrap.CmdLineTool - Invalid configuration
2017-06-29_12:44:16.73658 com.github.joschi.jadconfig.ParameterException: Couldn't convert value for parameter "root_timezone"
2017-06-29_12:44:16.73728 at com.github.joschi.jadconfig.JadConfig.processClassFields(JadConfig.java:141) ~[graylog.jar:?]
2017-06-29_12:44:16.73809 at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:99) ~[graylog.jar:?]
2017-06-29_12:44:16.73849 at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:351) [graylog.jar:?]
2017-06-29_12:44:16.73924 at org.graylog2.bootstrap.CmdLineTool.readConfiguration(CmdLineTool.java:344) [graylog.jar:?]
2017-06-29_12:44:16.73967 at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:177) [graylog.jar:?]
2017-06-29_12:44:16.74048 at org.graylog2.bootstrap.Main.main(Main.java:44) [graylog.jar:?]
2017-06-29_12:44:16.74092 Caused by: com.github.joschi.jadconfig.ParameterException: Couldn't convert value "US" to DateTimeZone.
2017-06-29_12:44:16.74143 at com.github.joschi.jadconfig.jodatime.converters.DateTimeZoneConverter.convertFrom(DateTimeZoneConverter.java:26) ~[graylog.jar:?]
2017-06-29_12:44:16.74187 at com.github.joschi.jadconfig.jodatime.converters.DateTimeZoneConverter.convertFrom(DateTimeZoneConverter.java:12) ~[graylog.jar:?]
2017-06-29_12:44:16.74271 at com.github.joschi.jadconfig.JadConfig.convertStringValue(JadConfig.java:167) ~[graylog.jar:?]
2017-06-29_12:44:16.74373 at com.github.joschi.jadconfig.JadConfig.processClassFields(JadConfig.java:139) ~[graylog.jar:?]
2017-06-29_12:44:16.74440 ... 5 more
2017-06-29_12:44:16.74504 Caused by: java.lang.IllegalArgumentException: The datetime zone id 'US' is not recognised
2017-06-29_12:44:16.74542 at org.joda.time.DateTimeZone.forID(DateTimeZone.java:229) ~[graylog.jar:?]
2017-06-29_12:44:16.74572 at com.github.joschi.jadconfig.jodatime.converters.DateTimeZoneConverter.convertFrom(DateTimeZoneConverter.java:24) ~[graylog.jar:?]
2017-06-29_12:44:16.74630 at com.github.joschi.jadconfig.jodatime.converters.DateTimeZoneConverter.convertFrom(DateTimeZoneConverter.java:12) ~[graylog.jar:?]
2017-06-29_12:44:16.74672 at com.github.joschi.jadconfig.JadConfig.convertStringValue(JadConfig.java:167) ~[graylog.jar:?]
2017-06-29_12:44:16.74736 at com.github.joschi.jadconfig.JadConfig.processClassFields(JadConfig.java:139) ~[graylog.jar:?]
2017-06-29_12:44:16.74778 ... 5 more
I just resolved the timezone, but still experiencing the same problem.
Graylog is restarting…
There is no Graylog web application running at the moment, please reload this page in a minute. It can take up to 1-2 minutes until all services are running properly. In case this is a permanent error, check the following:
Check if all services are running - sudo graylog-ctl status shows an overview of all running services
Check for errors in log files - Relevant services write log files here: /var/log/graylog/*/current
Ask for help - If there is no way to fix the issue ask for help: https://github.com/Graylog2/graylog2-images/issues
This graylog-ctl only configures the time zone used in Graylog, not the system timezone in the virtual machine.
Is it the same error message in the logs or are there other messages?
