I have ran into nothing but problems trying to convert the OVA to be usable under Hyper-V. Any time I run a graylog-ctl command I get stuck at Graylog is restarting when browsing to the webpage. Wiped the VM and started over. Attempted to set a static IP by editing /etc/network/interfaces and after rebooting the VM I was back to the Graylog is restarting screen. Wiped the VM and started over again. Attempted to set a DHCP reservation and now have an error that Elasticsearch cluster unavailable.
Any warnings or errors in the logs of your Graylog node?
http://docs.graylog.org/en/2.2/pages/configuration/file_location.html#omnibus-package
I ended up setting up a CentOS server and installing to it instead of using the OVA.
