Graylog can't start on cenos
Hi, I tried to run graylog on CentOS Linux release 7.6.1810 (Core) machineA and everything works well.
Then I copyied docker images and docker-compose.yml to another CentOS Linux release 7.6.1810 (Core) machineB, repeat same but failed
docker-compose.yml:
version: '3'
services:
    mongo:
      image: mongo:4.2
      networks:
        - graylog
    # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
        - "ES_JAVA_OPTS=-Dlog4j2.formatMsgNoLookups=true -Xms512m -Xmx512m"
      ulimits:
        memlock:
          soft: -1
          hard: -1
      deploy:
        resources:
          limits:
            memory: 1g
      networks:
        - graylog
    graylog:
      image: graylog/graylog:4.3
      environment:
        - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
        # Password: admin
        - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
        - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9005
        - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9005/
      entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      networks:
        - graylog
      restart: always
      depends_on:
        - mongo
        - elasticsearch
      ports:
        - 9005:9005
        # Syslog TCP
        - 1515:1515
        # Syslog UDP
        - 1515:1515/udp
        # GELF TCP
        - 12202:12202
        # GELF UDP
        - 12202:12202/udp
networks:
    graylog:
      driver: bridge
I tried to load saved image and run another centos machine with commands below:
docker load -i es.tar
docker load -i graylog.tar
docker load -i mongo.tar
docker-compose up
log shows:
docker ps shows:
Hey there. Just a quick note on some general forum etiquette – posting the same issue onultiple topics (I’m referring to Graylog failed to run when transfering images to another centos machine is not likely to get you an answer quicker. While folks are generally happy to help, we all do so on our own time, so if you’re needing immediate answers, Graylog offers support that has an SLA.
It’s not immediately clear what you’re trying to accomplish by taring up your images. If you need the data, you’re better off doing Mongodump and ES snapshot and restoring those to the other vm.
