Graylog fail to run on centos when transfering images to another machine
Hi, I tried to run graylog on CentOS Linux release 7.6.1810 (Core) machine A and everything works well.
Then I copyied docker images and docker-compose.yml to another CentOS Linux release 7.6.1810 (Core) machine B, repeat same but failed
docker-compose.yml:
version: '3'
services:
    mongo:
      image: mongo:4.2
      networks:
        - graylog
    # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
        - "ES_JAVA_OPTS=-Dlog4j2.formatMsgNoLookups=true -Xms512m -Xmx512m"
      ulimits:
        memlock:
          soft: -1
          hard: -1
      deploy:
        resources:
          limits:
            memory: 1g
      networks:
        - graylog
    graylog:
      image: graylog/graylog:4.3
      environment:
        - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
        # Password: admin
        - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
        - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9005
        - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9005/
      entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      networks:
        - graylog
      restart: always
      depends_on:
        - mongo
        - elasticsearch
      ports:
        - 9005:9005
        # Syslog TCP
        - 1515:1515
        # Syslog UDP
        - 1515:1515/udp
        # GELF TCP
        - 12202:12202
        # GELF UDP
        - 12202:12202/udp
networks:
    graylog:
      driver: bridge
I tried to load saved image and run another centos machine with commands below:
docker load -i es.tar
docker load -i graylog.tar
docker load -i mongo.tar
docker-compose up
startup log shows:
I saved images by command docker save -o.
docker ps shows:
Hello @hel
Hard to read the screen shots over here. from what I can see it looks like you maybe missing
Plugin _dir and something called realpath: operand which I’m not sure of.
Is it possible to show full log for graylog?
@gsmith
docker graylog logs:
graylog_1    | realpath: missing operand
graylog_1    | Try 'realpath --help' for more information.
graylog_1    | wait-for-it: waiting 15 seconds for elasticsearch:9200
graylog_1    | wait-for-it: elasticsearch:9200 is available after 11 seconds
graylog_1    | find '/plugins-default/': No such file or directory
cp_graylog_1   exited with code 1
graylog_1    | wait-for-it: elasticsearch:9200 is available after 0 seconds
process of elasticsearch and mongo seems works well
hello,
I see these two, have you check the plugin directory?
The container of graylog doesn’t startup successfully, so I can’t enter the container to check that directory. That container is always in restarting.
Hey,
What does it show in the logs why Docker cant start your container?
I know I had to reference my journalctl -x. Are you able to check the rest of the logs to find out why Graylog container will not start?
@hel
This is my compose file, not sure if it will help but You can see I have a plugin directory
graylog:
    #image: graylog/graylog-enterprise:4.3.3-jre11
    image: graylog/graylog-enterprise:4.3.8-jre11
    network_mode: bridge
    dns:
      - 8.8.8.8
      - 8.8.4.4
   # journal and config directories in local NFS share for persistence
    volumes:
       - graylog_bin:/usr/share/graylog-server/bin/
       - graylog_data:/usr/share/graylog/data/config
       - graylog_log:/usr/share/graylog/data/log
       - graylog_plugin:/usr/share/graylog/data/plugin
       - graylog_content:/usr/share/graylog/data/contentpacks
      # Mount local configuration directory into Docker container
       - graylog_scripts:/usr/share/graylog/scripts
    environment:
      # Container time Zone
      - TZ=America/Chicago
      - GRAYLOG_PASSWORD_SECRET=pJod1TRZAckHmqM2oQPqX1qnLV
I have posted docker logs above. The log repeats
graylog_1 | realpath: missing operand graylog_1 | Try 'realpath --help' for more information. graylog_1 | wait-for-it: waiting 15 seconds for elasticsearch:9200 graylog_1 | wait-for-it: elasticsearch:9200 is available after 11 seconds graylog_1 | find '/plugins-default/': No such file or directory cp_graylog_1 exited with code 1
I run graylog with docker-compose. docker-compose.yml is the same with Docker and Example Version 3 section.
version of docker is : 1.13.1
hey,
I understand , Hence why I was suggesting and defining the logs for you.
EDIT:
Unfortunately those logs don’t help as much as other logs would have to troubleshoot this issue.
Posting them would or might have helped. Sorry I cant be further assistance.
@hel So…Docker 1.13.1 is 5 years old (see Docker Engine release notes | Docker Documentation). Is there a reason you’re running such an old version and not running something that’s more recent (FWIW, the current docker version is 20.10.1 Docker Engine release notes | Docker Documentation). I think you’d find that running a more recent version of Docker that’s supported would give you a better result.
@aaronsachs Yes. I upgrade docker to v20.10.9 and graylog startup successfully. The Welcome page of graylog is shown. The /api/system/sessions returns 200 and session_id is returned./api/users/admin returns 401. /api/users/admin is sent without cookie by browser. There is no proxy.
Username and password is correct.
How can I find log file to solve this 401 problem. Thanks.
And api/system/sessions also returns valid_util. Its value is very near to the time the reponse is received. It seems to affect Response’s Set-Cookie Expires value. I don’t whether it’s related to the 401 response.
It’s my local network issue. After upgrading docker, graylog works well. Thanks.
Ah! Good to know. Thanks for the update!
