Graylog failed to run when transfering images to another centos machine
Hi, I tried to run graylog on CentOS Linux release 7.6.1810 (Core) machine A and everything works well.
Then I copyied docker images and docker-compose.yml to another CentOS Linux release 7.6.1810 (Core) machine B, repeat same but failed
docker-compose.yml:
version: '3'
services:
    mongo:
      image: mongo:4.2
      networks:
        - graylog
    # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
        - "ES_JAVA_OPTS=-Dlog4j2.formatMsgNoLookups=true -Xms512m -Xmx512m"
      ulimits:
        memlock:
          soft: -1
          hard: -1
      deploy:
        resources:
          limits:
            memory: 1g
      networks:
        - graylog
    graylog:
      image: graylog/graylog:4.3
      environment:
        - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
        # Password: admin
        - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
        - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9005
        - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9005/
      entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      networks:
        - graylog
      restart: always
      depends_on:
        - mongo
        - elasticsearch
      ports:
        - 9005:9005
        # Syslog TCP
        - 1515:1515
        # Syslog UDP
        - 1515:1515/udp
        # GELF TCP
        - 12202:12202
        # GELF UDP
        - 12202:12202/udp
networks:
    graylog:
      driver: bridge
I tried to load saved image and run another centos machine with commands below:
docker load -i es.tar
docker load -i graylog.tar
docker load -i mongo.tar
docker-compose up
docker log
graylog_1          | realpath: missing operand
graylog_1          | Try 'realpath --help' for more information.
graylog_1          | wait-for-it: waiting 15 seconds for elasticsearch:9200
graylog_1          | wait-for-it:  elasticsearch:9200 is available after 0 seconds
graylog_1          | find '/plugins-default': No such file or directory
cp_graylog_1 exited with code 1
log shows:
docker ps shows elasticsearch and mongo works well.
Posting multiple time will not help you issue
