Can't get docker graylog up and running
Hi Guys!
We are trying to get graylog up and running on docker using this guide:
https:// hub.docker.com/r/graylog/graylog/
This is the content of the compose file
version: '2'
 services:
   # MongoDB: https   ://hub.docker.com/_/mongo/
   mongo:
     image: mongo:3
     volumes:
       - mongo_data:/data/db
   # Elasticsearch: https   ://www.elastic.co/guide/en/elasticsearch/reference/5.5/docker.html
   elasticsearch:
     image: docker.elastic.co/elasticsearch/elasticsearch:5.6.12
     volumes:
     environment:
       - http.host=0.0.0.0
       - transport.host=localhost
       - network.host=0.0.0.0
       # Disable X-Pack security: https   ://www.elastic.co/guide/en/elasticsearch/reference/5.5/security-settings.html#general-security-settings
       - xpack.security.enabled=false
     ulimits:
       memlock:
         soft: -1
         hard: -1
     mem_limit: 1g
   # Graylog: https   ://hub.docker.com/r/graylog/graylog/
   graylog:
     image: graylog/graylog:2.4
     volumes:
       - ./graylog_journal:/usr/share/graylog/data/journal
       - ./graylog/config:/usr/share/graylog/data/config
     environment:
       # CHANGE ME!
       - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
       # Password: admin
       - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
       - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
     links:
       - mongo
       - elasticsearch
     ports:
       - 9000:9000
       # Syslog TCP
       - 514:514
       # Syslog UDP
       - 514:514/udp
       # GELF TCP
       - 12201:12201
       # GELF UDP
       - 12201:12201/udp
 # Volumes for persisting data, see https   ://docs.docker.com/engine/admin/volumes/volumes/
 volumes:
   mongo_data:
     driver: local
   es_data:
     driver: local
   graylog_journal:
     driver: local
Our issue is we keep getting these errors when doing docker-compose up
 graylog_1        | ERROR StatusLogger File not found in file system or classpath: /usr/share/graylog/data/config/log4j2.xml
 graylog_1        | ERROR StatusLogger Reconfiguration failed: No configuration found for '74a14482' at 'null' in 'null'
 graylog_1        | 02:15:02.399 [main] ERROR org.graylog2.bootstrap.CmdLineTool - Couldn't load configuration: Properties file /usr/share/graylog/data/config/graylog.conf doesn't exist!
Now we have followed the instruction to download the graylog.conf and log4j2.xml from:
    wget https   ://raw.githubusercontent.com/Graylog2/graylog-docker/3.0/config/graylog.conf
    wget https   ://raw.githubusercontent.com/Graylog2/graylog-docker/3.0/config/log4j2.xml
and the file is pressent in the requested folder:
 i4admin@docker01:/usr/share/graylog/data/config$ ls
 graylog.conf  log4j2.xml
We did find this article:
https ://github.com/Graylog2/graylog2-server/issues/2996
and we did correct the docker compose file according to this post:
I had the same problem despite of following docs. I notice there are missing points at the beginning of each line:
    volumes:
       - ./graylog/data/journal:/usr/share/graylog/data/journal
But that didn’t take care of the error.
We need help!
oh and the spaces after https is because the forum wouldn’t lets us post more then 2 links. they are ofcause not there in the file
the easiest way to paste configuration and logfiles is to put them in a code block and not a quote …
Your text here
I have actually just copy and pasted the content from the documentation: http://docs.graylog.org/en/2.5/pages/installation/docker.html#persisting-data
That is working without any issues. So please verify that you have taken the part from the documentation
