Input failed to start after https
Hi Guys,
I have a setup of graylog on docker which runs perfectly fine on http and recently we had a requirement to move that to https.
version: ‘2’
services:
MongoDB: https://hub.docker.com/_/mongo/
mongodb:
image: mongo:3
volumes:
- mongo_data:/data/db
Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.x/docker.html
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.2
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=10.4.1.3
- “ES_JAVA_OPTS=-Xms512m -Xmx512m”
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
Graylog: https://hub.docker.com/r/graylog/graylog/
graylog:
image: graylog/graylog:3.1
volumes:
volumes:
- ./certs/graylog.crt:/certs/graylog.crt
- ./certs/graylog.key:/certs/graylog.key
environment:
- GRAYLOG_PASSWORD_SECRET=sysnetgraylogserverforaws
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=c674ad0246d53361ee006b2ab11ae465331d387e7aea1ea4b2a25a75f038b69e
- GRAYLOG_HTTP_EXTERNAL_URI=https://graylog.xxxxx.com:9000/
- GRAYLOG_HTTP_ENABLE_TLS=true
- GRAYLOG_HTTP_TLS_CERT_FILE=/certs/graylog.crt
- GRAYLOG_HTTP_TLS_KEY_FILE=/certs/graylog.key
- GRAYLOG_REST_TLS_CERT_FILE=/certs/graylog.crt
- GRAYLOG_REST_TLS_KEY_FILE=/certs/graylog.key
links:
  - mongodb:mongo
  - elasticsearch
depends_on:
  - mongodb
  - elasticsearch
ports:
  - 9000:9000
- 443:443
  - 443:9000
  # Syslog TCP
  - 1514:1514
  # Syslog UDP
  - 1514:1514/udp
  # GELF TCP
  - 12201:12201
  # GELF UDP
  - 12201:12201/udp
Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
And I have configured https in my docker config and it starts fine and was able to access web interface via https. But the input doesn’t start and below is my docker config.
ERROR: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I think it’s related to adding to Keystore I know how to do it regular Graylog server
NOTE: certificate is not self signed
can anyone help me out on how to do this using docker?
Hi Guys,
Can anyone point me in the right direction for this ?
yes @kvenkat971
I guess that the first non-loopback ip in this setup is not part of your certificate - what means the validation chain is not valid.
thanks @jan
I have like two certificates one for web and one for rest tls which includes the IP address but I still get the same error .
And I have imported the self signed for IP into keystore.
Below is my new config
version: ‘2’
services:
mongodb:
image: mongo:3
volumes:
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.5
volumes:
environment:
- http.host=0.0.0.0
- network.host=127.0.0.1
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
image: graylog/graylog:3.2.2
volumes:
volumes:
- ./certs/ip.crt:/certs/ip.crt
- ./certs/ip.key:/certs/ip.key
environment:
- GRAYLOG_PASSWORD_SECRET=serverforaws
# Password: admin
- GRAYLOG_REST_TRANSPORT_URI=http://:9000/api
- GRAYLOG_HTTP_EXTERNAL_URI=https://graylog.example.com:9000/
- GRAYLOG_REST_ENABLE_TLS=true
- GRAYLOG_REST_TLS_CERT_FILE=/certs/ip.crt
- GRAYLOG_REST_TLS_KEY_FILE=/certs/ip.key
- GRAYLOG_REST_TLS_KEY_PASSWORD=secret
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
- 443:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
Can you let me know is there anything wrong with my config ?
I do not know where you get the feeling from that you need to use
that configuration parameter is not given anymore in Graylog 3.2
you need one certificate that is able to verify the http_external_uri and the http_publish_uri at the same time.
@jan,
I tried that configuration only because I had the same error for the below config which my original config is based on
  - GRAYLOG_HTTP_EXTERNAL_URI=https://graylog.sysnetgs.com:9000/
  - GRAYLOG_HTTP_PUBLISH_URI=https://graylog.sysnetgs.com:9000/
let me know if there is anything worng in the above
he @kvenkat971
does graylog.sysnetgs.com resolve to a local ip on that container for the container itself?
@jan, yes it does resolve
@jan, I can’t seem to find the location for java in docker Graylog. can you help me out with the location?
I’m using Graylog 3.2.2
is this a self signed certificate?
if yes you need to add this to a java keystore and add this keystore to the startup parameters of Graylog.
@jan, it is not a self-signed cert.
it was issued by an authorised third party.
have some news on this tried this just a few minutes ago,
I got it working if I do key tool import of the cert inside the container, but I’m looking for a line that I can add to the compose file while starting the container itself.
any suggestions on the config to add the keytool to the compose file so that when the container reboots?
Add the additional Java server opts to the compose file.
@jan thank you. That worked like a charm
