Tips installing Graylog on Fedora Server 32 using Docker
Depending on your root configuration you might need to sudo all command
1) Use grubby to set kernel to avoid the error - "docker: Error response from daemon: OCI runtime create failed: "
sudo grubby --update-kernel=ALL --args="systemd.unified_cgroup_hierarchy=0"
and reboot
sudo reboot
2) Use dnf to install docker and docker-compose; first check if dnf-plugins-core is installed
sudo dnf -y install dnf-plugins-core
sudo dnf install dockerd
sudo dnf install docker-compose
and reboot
sudo reboot
3) Then create a directory for graylog; I chose /opt/graylog
cd /opt
mkdir /graylog
4) Then create the following directory structure
/opt/graylog/data
/opt/graylog/data/config
/opt/graylog/data/journal
/opt/graylog/elasticsearchdata
/opt/graylog/mongodb
5) Next we need to put down some config files
cd /opt/graylog/data/config
wget https://raw.githubusercontent.com/Graylog2/graylog-docker/3.2/config/graylog.conf
wget https://raw.githubusercontent.com/Graylog2/graylog-docker/3.2/config/log4j2.xml
6) Now we need to create a dummy node-id file
still in the config directory
touch node-id
7) Apply security to data, mongodb and elasticsearchdata
chmod -R 777 /opt/graylog/<folder>
chown -R 1000:1000 /opt/graylog/<folder>
8) Next is the docker-compose file
cd /opt/graylog
nano docker-compose.yml
Remember to change mylinuxip to your linux machine’s IP xxx.xxx.xxx.xxx
version: '3'
services:
  mongo:
    image: mongo:3
    user: 1000:1000
    networks:
      - graylog
    restart: always
    volumes:
      - /opt/graylog/mongodb:/data/db:z
  # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.x/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.5
    user: 1000:1000
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
    ulimits:
      memlock:
        soft: -1
        hard: -1
    deploy:
      resources:
        limits:
          memory: 1g
    networks:
      - graylog
    restart: always
    volumes:
      - /opt/graylog/elasticsearchdata:/usr/share/elasticsearch/data:z
  graylog:
    image: graylog/graylog:3.2
    environment:
      - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
      - GRAYLOG_HTTP_EXTERNAL_URI=http://mylinuxip:9000/
    networks:
      - graylog
    depends_on:
      - mongo
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      # Syslog UDP
      - 1514:1514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
    restart: always
    volumes:
      - /opt/graylog/data/journal:/usr/share/graylog/data/journal:z
      - /opt/graylog/data/config:/usr/share/graylog/data/config:z
networks:
  graylog:
    driver: bridge
8. Firewall to resolve later; let’s just disable it for now and restart docker
sudo systemctl stop firewalld
sudo systemctl restart docker
9. Start Graylog
cd /opt/graylog
docker-compose up
10. In a browser connect to Graylog
http://yourlinuxup:9000
11. You can break out using Ctrl-C and then a
docker-compose down
12. Fix the firewall
Temporarily disable it from starting
sudo systemctl disable firewalld
13. Let Graylog docker-compose start on boot
All of the services run when you reboot your system if you run below command only once
docker-compose up -d
14. Some handy commands
docker-compose logs
docker volume ls
delete all volumes; carefull with this one
docker volume rm $(docker volume ls -q)
Hope this help someone; was a couple of hours research and not perfect, might have missed something. I am a relative NOOB @ Linux so forgive me if it is not 100%.
Thank you, this is exactly what I needed both for home and for the work :slight_smile:
