Graylog and API
Hi ,
I have download the ova package, import and deploy on ESX. The vm start, just need config the network interfaces and do a graylog-ctl reconfigure.
Well, the message is the server is unavailable. Issue with the rest api… Great !!!
I can do a curl on localhost:9000 wortks
I can do a curl on :9200 for ES and works
but why I can’t log to the graylog web server and why I have always the issue with rest api???
Hej @Globule
did you follow the getting started guide?
http://docs.graylog.org/en/2.2/pages/getting_started.html
with kind regards
Jan
