HTTPS problem when login
I apologize in advance if the topic has already been discussed but this is the first time I use graylog.
Downloaded and deployed OVA image on ESX and all is fine. I changed some parameters use graylog-ctl enforce-ssl (for example). It switches now to https but after login i encounter 404 issue, while in http the problem is not present.
What parameter do i change?
Thanks,
could you share your server.conf (probably) in /opt/graylog/conf/graylog.conf?
Do you get any logs in /var/log/graylog/server/?
The default file locations can be found here http://docs.graylog.org/en/2.3/pages/configuration/file_location.html#default-file-locations
Which commands did you run exactly and what was their output?
sudo graylog-ctl enforce-ssl
…and what was their output?
I’m also sure that this wasn’t the only command you’ve been running.
sure, only that command. No output came up when I run it.
Other commands was about admin password and timezone.
Now after login the issue is:
Error - the server returned: 404 - cannot POST
https://server_ip_address:443/api/system/sessions (404)
