Graylog not starting via HTTPS
My dashboard is not being loaded in HTTPS at port 9000
  • OS Information:
Operating System: Ubuntu 22.04.1 LTS
Kernel: Linux 5.17.0-1020-oem
Architecture: x86-64
  • Package Version: Graylog 4.1, mongoDB 4.4
systemctl status from graylog (issued):
graylog-server[79052]: 23:41:38.322 [main] ERROR org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: unexpected end of stream on *http:// 192.168. 15.168: 9200/… - \n not found: limit=0 content=….
/etc/graylog/server/server.conf:
elasticsearch_hosts = http ://user:pw@192. 168. 15.168: 9200 (user pw differente from this print)
password_secret = j2tB(…)G8iv
root_password_sha2 = 8(…)fd
opensearch_dashboards.yml:
server.host: 0.0.0.0
server.port: 443
opensearch.hosts: *htt ps://1 92.168.15.16 8:9 200
opensearch.ssl.verificationMode: certificate
Root CA imported with successfull:
Command:keytool -importcert -keystore /etc/graylog/server/certs/cacerts -storepass changeit -alias root_ca -file /etc/graylog/server/certs/root-ca.pem
Alias name: root_ca
Creation Date: Nov 16 from 2022
Entry type: trustedCertEntry
Owner: L=California, O=Wazuh, OU=Wazuh
Issuer: L=California, O=Wazuh, OU=Wazuh
Serial number: 3(…)3
Valid from: Wed Nov 16 11:58:18 EDT 2022 until: Sat Nov 13 11:58:18 EDT 2032
Certificate Fingerprints:
SHA1: A0:…:34
SHA256: 88:…:3A: 0B:…F3
Signature Algorithm Name: SHA256withRSA
Subject Public Key Algorithm: 2048-bit RSA key
Version: 3
Extensions:
#1: ObjectId: 2.5.29.35 Criticality=false
AuthorityKeyIdentifier [
KeyIdentifier [
0000: 96 … 6F …xU.C…A…to
0010: 4E … N%…
:brazil:
:brazil:
#2: ObjectId: 2.5.29.19 Criticality=true
BasicConstraints:[
CA:true
PathLen: no limit
:brazil:
#3: ObjectId: 2.5.29.14 Criticality=false
SubjectKeyIdentifier [
KeyIdentifier [
0010: 4E … N%…
:brazil:
:brazil:
/etc/default/graylog-server (line to gralyog uses the ssl certificate):
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true -Djavax.net.ssl.trustStore=/etc/graylog/server/certs/cacerts -Djavax.net.ssl.trustStorePassword=changeit”
Restart the graylog service and validate the config, with the correct setup, the graylog cannot start the service to open GUI (even with status running), the htt ps://i p:920 0 does not load the GUI and service has the status:
ERROR org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: unexpected end of stream on *htt p:/ /192 .1 68.15.16 8:9200/… - \n not found: limit=0 content=…
Please, kidnly help me to evaluate what is wrong in this configuration between wazhu and gralyog to uses SSL for HTTPS.
Thank you and Best Regards,
I had a similar issue in the past.
To fix it, I edited /etc/graylog/server/server.conf and added:
elasticsearch_version = 7
Then restarted Graylog.
I assume that your GL server can reach ES.
Do the files
/etc/wazuh-dashboard/certs/dashboard-key.pem
and
/etc/wazuh-dashboard/certs/dashboard.pem
have the right permissions for the graylog user to read them?
If you accept a suggestion, install and configure nginx as a reverse proxy and access GL on port 80 or 443. Makes things easier…
HTH
Hi m_mlk
Thank you for your sugestion, I will not perform at this time, while I need to finish this install at least.
Regarding your fix, does not worked for me, see that I’ve edit the file with version proposed
3
Also see that certs has the readle chmod values 444 for root, users and everyone:
(I’ll sent in trailling below)
But even do, system is not found by Graylog after a restart
Thank you for your help.
2
I Found the fix guys, is totally simples.
Just edit the /etc/graylog/server/server.conf at the elasticsearch_hosts from http to https
from elasticsearch_hosts = http://:@:9200
to elasticsearch_hosts = https://:@:9200
