Hello, friends!
I’m having some trouble with the Graylog Docker environment.
The container keeps exiting:
graylog_graylog-datanode.1 graylog/graylog-datanode:6.2.2@sha256:175fb39e4b03eba708c189c01d34a1c7c20a33c5f525df962ca521276289191e azubuntu Running Running 6 minutes ago
graylog_graylog-mongodb.1 mongo:7.0.15@sha256:8958f43a940142d2a4572bb4d4f147ab26994a3da1cead6d39876b96451a4f1a azubuntu Running Running 6 minutes ago
graylog_graylog.1 graylog/graylog:6.2.2@sha256:62560590c1c74630bb2ff84867d2bf603db8aeb8c91fbcc9da3355b2f24ab3f3 azubuntu Running Starting 16 seconds ago
\_ graylog_graylog.1 graylog/graylog:6.2.2@sha256:62560590c1c74630bb2ff84867d2bf603db8aeb8c91fbcc9da3355b2f24ab3f3 azubuntu Shutdown Failed 21 seconds ago "task: non-zero exit (143): dockerexec: unhealthy container"
\_ graylog_graylog.1 graylog/graylog:6.2.2@sha256:62560590c1c74630bb2ff84867d2bf603db8aeb8c91fbcc9da3355b2f24ab3f3 azubuntu Shutdown Failed 2 minutes ago "task: non-zero exit (143): dockerexec: unhealthy container"
\_ graylog_graylog.1 graylog/graylog:6.2.2@sha256:62560590c1c74630bb2ff84867d2bf603db8aeb8c91fbcc9da3355b2f24ab3f3 azubuntu Shutdown Failed 4 minutes ago "task: non-zero exit (143): dockerexec: unhealthy container
I’ve edited “health_check.sh” to see at which check it fails, resulting in:
=== Graylog Healthcheck Script Debug ===
[info] Default proto: http
[info] Default bind address: 127.0.0.1:9000
[info] Found config file at /usr/share/graylog/data/config/graylog.conf
[config] http_publish_uri from config: ''
[config] http_bind_address from config: '0.0.0.0:9000'
[config] http_enable_tls from config: ''
[env] GRAYLOG_HTTP_PUBLISH_URI: http://graylog:9002
[debug] Overridden http_publish_uri: graylog:9002
[debug] Overridden http_bind_address: 0.0.0.0:9002
[check] Using check_url: http://graylog:9002
[curl] Checking http://graylog:9002/api
* Trying 10.0.2.3:9002...
* Connected to graylog (10.0.2.3) port 9002 (#0)
> GET / HTTP/1.1
> Host: graylog:9002
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 401 Unauthorized
< WWW-Authenticate: Basic realm=preflight-config
< Content-Type: text/plain
< Content-Length: 62
* The requested URL returned error: 401
* Closing connection 0
[curl] Primary check failed. Trying fallback: http://127.0.0.1/api
* Trying 127.0.0.1:80...
* connect to 127.0.0.1 port 80 failed: Connection refused
* Failed to connect to 127.0.0.1 port 80 after 0 ms: Connection refused
[error] All health checks failed. Exiting with code 1
By the script output, combined with other curl tests, I believe that there is nothing wrong with setup, as it is possible to see that it is even requesting authorization and that the socket is opened and listening:
# 9002 opened, requesting auth:
graylog@graylog:~$ curl --verbose a:a@graylog:9002/
* Trying 10.0.1.107:9002...
* Connected to graylog (10.0.1.107) port 9002 (#0)
* Server auth using Basic with user 'a'
> GET / HTTP/1.1
> Host: graylog:9002
> Authorization: Basic YTph
> Accept: */*
* Authentication problem. Ignoring this.
< Content-Length: 71
* Connection #0 to host graylog left intact
You cannot access this resource, invalid username/password combination!
# 9000 Closed, as it should per configuration:
graylog@graylog:~$ curl --verbose a:a@graylog:9000/
* Trying 10.0.1.107:9000...
* connect to 10.0.1.107 port 9000 failed: Connection refused
* Trying 10.0.2.14:9000...
* connect to 10.0.2.14 port 9000 failed: Connection refused
* Failed to connect to graylog port 9000 after 1 ms: Connection refused
curl: (7) Failed to connect to graylog port 9000 after 1 ms: Connection refused
In resume, the health check keeps failing and i don’t know why. I’d be grateful for any inputs that may help me. Thanks in advance!
Relevant config files:
graylog-compose.yml:
networks:
graylog_net:
driver: overlay
internal: true
attachable: true
traefik3_net:
external: true
volumes:
graylog_data:
driver: local
graylog_journal:
driver: local
services:
graylog:
image: graylog/graylog:6.2.2
hostname: "graylog"
env_file: ".env_graylog"
volumes:
- "graylog_data:/usr/share/graylog/data/data"
- "graylog_journal:/usr/share/graylog/data/journal"
networks:
- graylog_net
- traefik3_net
depends_on:
- graylog-mongodb
- graylog-datanode
deploy:
resources:
limits:
cpus: '0.50'
memory: 1024M
mode: replicated
replicas: 1
labels:
#redacted#
env file:
GRAYLOG_PASSWORD_SECRET=#redacted#
GRAYLOG_ROOT_PASSWORD_SHA2=#redacted#
GRAYLOG_NODE_ID_FILE=/usr/share/graylog/data/data/node-id
GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9002
GRAYLOG_HTTP_PUBLISH_URI=http://graylog:9002
GRAYLOG_HTTP_EXTERNAL_URI=http://graylog:9002/
GRAYLOG_MONGODB_URI=mongodb://#redacted#:#redacted#@graylog-mongodb:27017/graylog?authSource=users
