Description of your problem
When deploying Graylog using “docker stack deploy” it fails the healthcheck (apparently) if we set the http_publish_uri to anything other than 127.0.0.1, even though it starts successfully it will always fail after 120 seconds and quit, the problem is that this uri is not what we want to set, and the REST service then creates wrong urls…
This also does NOT happen if I use “docker-compose up”, this only happens if I use “docker stack deploy”, with nothing else getting changed. On docker-compose up the service starts succesfully with values other than 127.0.0.1.
Description of steps you’ve taken to attempt to solve the issue
If instead of setting my desired publish uri I set it to 127.0.0.1 the service goes up successfully.
Environmental information
Compose file version 3
Operating system information
Docker version 20.10.8
Deploying using docker stack deploy.
Package versions
graylog/graylog:4.1
docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
mongo:4.2
Mounted configuration file is default values with the exception of passwords and smtp values.
NOTE: For all container-based deployments, please include your full, redacted YAML configuration file
docker-compose.yml
version: '3'
services:
mongo:
image: mongo:4.2
deploy:
mode: replicated
replicas: 1
volumes:
- mongo_data:/data/db
networks:
- graylog-network
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
volumes:
environment:
- http.host=0.0.0.0
- discovery.type=single-node
- transport.host=localhost
- network.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
deploy:
mode: replicated
replicas: 1
resources:
limits:
memory: 1g
networks:
- graylog-network
graylog:
image: graylog/graylog:4.1
deploy:
mode: replicated
replicas: 1
volumes:
- graylog_data:/usr/share/graylog/data
- /docker/graylog/config:/usr/share/graylog/data/config
environment:
- GRAYLOG_HTTP_EXTERNAL_URI=https://myurl.com/
- GRAYLOG_HTTP_PUBLISH_URI=https://myurl.com/
entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 -- /docker-entrypoint.sh
networks:
- graylog-network
depends_on:
- mongo
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Log Ports
- 5555:5555
- 5555:5555/udp
networks:
graylog-network:
driver: overlay
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_data:
driver: local
Starting the stack with:
docker stack deploy --compose-file docker-compose.yml graylog
Edit: I just disabled healthcheck to test and the container stays up, but fails to respond, I’m clueless as to why it fails with “docker stack deploy” but works with “docker-compose up”.
