Graylog docker - http notification error
I’m able to install graylog docker via documents - quick start.
I can send POST request with curl -X POST -H "Content-Type: application/json" -d "{}" http://127.0.0.1:8080/test/alert with cors enabled, and it responds with status:200. Also I can receive the right message {}
I disabled the whitelist in graylog, so I can send the message to wherever I want.
But in Alters > notification tab, I received following message, and couldn’t receive any data with my server.
Am running graylog on http://127.0.0.1:9000 and How to fix the issue ?
Thanks.
so you run your Graylog in a docker container and point to localhost … did you forward the localhost from inside the Graylog docker container to your notification container/service or did you run that inside the same container?
127.0.0.1 IN the Graylog container is different from 127.0.0.1 of your workstation.
Yeah. I’m pretty new to the docker.
Here is what I also tried:
1—expose 8080 and 2 send the msg through http://0.0.0.0:8080/test/alert
Ideally I want to 3 bind graylog’s port to 8080 -p 8080:8080 and use the same port as my server, but it throws “port already in use” error.
4 send msg through http://0.0.0.0/test/alert
I tried different combinations, but none of them worked.
he @Truth1984
maybe this will help you to understand networking in docker: https://runnable.com/docker/basic-docker-networking
issue solved with:
