Graylog 3.0 Docker container behind Nginx reverse proxy
I just setup Graylog 3.0 in a Docker container and the server seems to start without issue (below is my docker-compose.yml file). Nginx, Mongo, and Elasticsearch are all on separate machines.
version: '3'
services:
  graylog:
    container_name: graylog
    restart: unless-stopped
    networks:
      - home
    ports:
      - '9000:9000'
      - '12201:12201'
      - '12201:12201/udp'
      - '1514:1514'
      - '1514:1514/udp'
      - '8514:8514/udp'
    environment:
      - 'GRAYLOG_MONGODB_URI=mongodb://mongodb:27017/graylog'
      - 'GRAYLOG_ELASTICSEARCH_HOSTS=http://elasticsearch:9200'
      - 'GRAYLOG_PASSWORD_SECRET=97B4F23C7FCA34776EA399DAF5D3B384F4C64B3EA723DD28AAFE5F2ECB559310'
      - 'GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918'
      - 'GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000'
      - 'GRAYLOG_HTTP_PUBLISH_URI=http://10.10.2.21:9000/'
      - 'GRAYLOG_HTTP_EXTERNAL_URI=https://graylog.internal.domain.com/'
    volumes:
      - graylog_data:/usr/share/graylog/data
    image: graylog/graylog:3.0
networks:
  home:
    external: true
volumes:
  graylog_data:
    driver: local
I can login at https://graylog.internal.domain.com/ via my Nginx reverse proxy. This Nginx instance is not on the same container as Greylog, it is on another machine. The address 10.20.2.21 is my Docker host.
  location / {
    proxy_pass         http://10.10.2.21:9000/;
    proxy_set_header   Host                  $host;
    proxy_set_header   X-Forwarded-For       $proxy_add_x_forwarded_for;
    proxy_set_header   X-Forwarded-Host      $host;
    proxy_set_header   X-Forwarded-Server    $host;
When I try to access anything with the API though, I see errors in the logs that look like this. What am I missing here? As a mentioned, the web interface works over HTTPS, but not when it needs to reference any data from the API.
2019-04-02 18:55:31,434 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://10.10.2.21:9000/api/system on node <8a0e6bb2-a894-4acd-93ab-65eab8d24e65>,
java.net.SocketTimeoutException: connect timed out,
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_212],
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_212],
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_212],
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_212],
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_212],
	at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_212],
	at okhttp3.internal.platform.Platform.connectSocket(Platform.java:129) ~[graylog.jar:?],
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:245) ~[graylog.jar:?],
	at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:165) ~[graylog.jar:?],
	at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257) ~[graylog.jar:?],
	at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135) ~[graylog.jar:?],
	at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114) ~[graylog.jar:?],
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?],
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?],
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?],
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93) ~[graylog.jar:?],
	at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[graylog.jar:?],
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?],
	at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?],
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?],
	at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?],
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:180) ~[graylog.jar:?],
	at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?],
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212],
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212],
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212],
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212],
You’ll want to add this:
proxy_set_header X-Graylog-Server-URL https://$server_name;
Hmm, are you sure your settings regarding listen url etc. etc. are correct? Throw your server.conf on pastebin (remove all passwords etc. before you do) and drop the link here, it’ll give me some more info to work with :slight_smile:
is your Graylog able to connect to itself via:
Because you configured that Graylog can reach itself on that IP/PORT … please read the comments for this configuration settings.
