Graylog Docker NGINX Reverse Proxy HTTPS
Hi all, I hope someone can help as I am a bit of a noob on docker and containers and this is my first attempt at using docker and containers! At a high-level, my Graylog environment is currently setup like the following configuration:
  • Ubuntu 18.04 VM
  • Docker and docker compose installed on the Ubuntu VM
  • Graylog, Elasticsearch and MongoDB, Nginx and Certbot running as docker containers
  • Nginx is setup as a reverse proxy for port 80 to port 9000 on the Graylog container
What I really want to do is configure Nginx to secure connections to the VM using port 443/HTTPS which then forwards on port 9000 to the Graylog container. I have read the documentation with regards to using Nginx as a reverse proxy: https://docs.graylog.org/en/3.1/pages/configuration/web_interface.html#configuring-webif-nginx which all makes sense. What I can’t seem to get working is the Certbot which looks for a .well-known folder within Nginx I believe:
certbot          |    Domain: my.domain.net
certbot          |    Type:   unauthorized
certbot          |    Detail: Invalid response from
certbot          |    http://my.domain.net/.well-known/acme-challenge/uWWZoAes9tJDopP9oNJ3PQBIEt8P-Cek0FMdh3u9HvQ
certbot          |    [51.143.152.188]: "<html>\r\n<head><title>502 Bad
certbot          |    Gateway</title></head>\r\n<body>\r\n<center><h1>502 Bad
However, once that is working I am not sure what I should be changing to my nginx.conf file and what exactly needs to be changed in the docker-compose file.
Any help is greatly appreciated!
Below is my docker-compose file:
version: '2'
services:
  mongodb:
    image: mongo:3
    container_name: mongodb
    volumes:
      - mongo_data:/data/db
      - mongo_config:/data/configdb
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.2
    container_name: elasticsearch
    volumes:
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 1g
  # NGINX Configuration
  nginx:
    image: nginx
    container_name: nginx
    volumes:
      - ./nginx-conf:/etc/nginx/conf.d
    ports:
      - 80:80
      - 443:443
  # Certbot / Lets Encrypt Configuration
  certbot:
    image: certbot/certbot
    container_name: certbot
    volumes:
      - ./letsencrypt:/etc/letsencrypt
    command: certonly --standalone -d my.domain.net --staple-ocsp -m email@my.domain.net --agree-tos
  # Graylog:
  graylog:
    image: graylog/graylog:3.1
    container_name: graylog
    volumes:
       - graylog_data:/usr/share/graylog/data
    environment:
      - GRAYLOG_PASSWORD_SECRET=removedforprivacy
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=removedforprivacy
      - GRAYLOG_HTTP_EXTERNAL_URI=http://my.domain.net:9000/
      - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
    links:
      - mongodb:mongo
      - elasticsearch
      - nginx
      - certbot
    depends_on:
      - mongodb
      - elasticsearch
      - nginx
      - certbot
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      # Syslog UDP
      - 1514:1514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
# Volumes for persisting data
volumes:
  mongo_data:
    driver: local
  mongo_config:
    driver: local
  es_data:
    driver: local
  graylog_data:
    driver: local
  nginx_conf:
    driver: local
Below is my current nginx.conf:
server
    listen 80 default_server;
    listen [::]:80 default_server ipv6only=on;
    server_name my.domain.net;
    location / {
      proxy_set_header X-Graylog-Server-URL http://$server_name/;
      proxy_pass       http://my.domain.net:9000;
you should draw yourself a picture how the communication flow is. That will make it easier to understand the needed configurations.
NETWORK > ( Ubuntu > ( Docker > NGINX > Graylog ) )
You want all of that with https (port 443 from the outsite to what part in your stack?
NETWORK:443  > ( Ubuntu:443 > ( Docker:443 > NGINX:443 > Graylog:9000 ) )
If that is true, take care that x-graylog-server/http_external_uri includes https. In Graylog is not other definition needed.
I never used the certbot but your nginx configuration needs to include somewhere something like the following:
  	location ^~ /.well-known/acme-challenge {
    		default_type text/plain;
    		root /var/www/letsencrypt;
to map the folder to the location where the certificates can be verified.
