MoBO
October 21, 2020, 10:30am
1
Hello everyone,
I set GRAYLOG on Docker and it’s working fine on the device using HTTP on port 9000.
Unfortunately, I’m unable to make it work with the NGINX Reverse-Proxy of the SWAG container.
I was wondering if anyone is using this setup.
Tried many NGINX configurations without success (mostly not responding or blank page).
Thanks YOU
MoBO
October 21, 2020, 11:22am
2
Found it !
NGINX CONF FILE (xxx.subdomain.conf)
server {
listen 443 ssl;
server_name .*;
# No google, no no no
add_header X-Robots-Tag “noindex, nofollow, nosnippet, noarchive”;
include /config/nginx/ssl.conf;
client_max_body_size 0;
location / {
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_app <local_machine_name_full>;
set $upstream_port 9000;
set $upstream_proto http;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
proxy_set_header X-Graylog-Server-URL https://<exposed_https_address_with_subdomain>/;
GRAYLOG docker-compose
where;
${GRAYLOG_HTTP_EXTERNAL_URI} = http://yourservename:9000/
${GRAYLOG_HTTP_PUBLISH_URI} = http://yourservename:9000/
yep, both the same form me… it works so, not sure
environment:
- GRAYLOG_PASSWORD_SECRET=${GRAYLOG_PASSWORD_SECRET}
- GRAYLOG_ROOT_PASSWORD_SHA2=${GRAYLOG_ROOT_PASSWORD_SHA2}
- GRAYLOG_HTTP_EXTERNAL_URI=${GRAYLOG_HTTP_EXTERNAL_URI}
- GRAYLOG_HTTP_PUBLISH_URI=${GRAYLOG_HTTP_PUBLISH_URI}
- GRAYLOG_ELASTICSEARCH_INDEX_PREFIX=${GRAYLOG_ELASTICSEARCH_INDEX_PREFIX}
- TRANSPORT_EMAIL_ENABLED=${GRAYLOG_TRANSPORT_EMAIL_ENABLED}
- TRANSPORT_EMAIL_USE_AUTH=${GRAYLOG_TRANSPORT_EMAIL_USE_AUTH}
- TRANSPORT_EMAIL_HOSTNAME=${GRAYLOG_TRANSPORT_EMAIL_HOSTNAME}
- TRANSPORT_EMAIL_PORT=${GRAYLOG_TRANSPORT_EMAIL_PORT}
- TRANSPORT_EMAIL_AUTH_USERNAME=${GRAYLOG_TRANSPORT_EMAIL_AUTH_USERNAME}
- TRANSPORT_EMAIL_AUTH_PASSWORD=${GRAYLOG_TRANSPORT_EMAIL_AUTH_PASSWORD}
- TRANSPORT_EMAIL_USE_TLS=${GRAYLOG_TRANSPORT_EMAIL_USE_TLS}
- TRANSPORT_EMAIL_USE_SSL=${GRAYLOG_TRANSPORT_EMAIL_USE_SSL}
- TRANSPORT_EMAIL_SUBJECT_PREFIX=${GRAYLOG_TRANSPORT_EMAIL_SUBJECT_PREFIX}
- TRANSPORT_EMAIL_FROM_EMAIL=${GRAYLOG_TRANSPORT_EMAIL_FROM_EMAIL}
- TRANSPORT_EMAIL_TRANSPORT_EMAIL_WEB_INTERFACE_URL=${GRAYLOG_TRANSPORT_EMAIL_TRANSPORT_EMAIL_WEB_INTERFACE_URL}
- TZ=${GLB_TZ_ZRH}
Hope this will help someone.
