Unable to reach graylog ui while using docker and nginx reverse proxy
Hi all, I’m having some issues getting graylog setup in our AWS environment. Our setup is pretty simple with having a docker image with graylog, nginx, and mongodb. Then using an AWS elasticsearch cluster.
When navigating to our website nginx logs the following messages:
nginx_1    | 2018/09/20 22:37:36 [error] 5#5: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 96.78.0.242, server: staging.logs.payments.campspot.com, request: "GET / HTTP/1.1", upstream: "http://172.18.0.3:9000/", host: "staging.logs.payments.campspot.com"
nginx_1    | 96.78.0.242 - - [20/Sep/2018:22:37:36 +0000] "GET / HTTP/1.1" 502 575 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
nginx_1    | 2018/09/20 22:37:37 [error] 5#5: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 96.78.0.242, server: staging.logs.payments.campspot.com, request: "GET /favicon.ico HTTP/1.1", upstream: "http://172.18.0.3:9000/favicon.ico", host: "staging.logs.payments.campspot.com", referrer: "http://staging.logs.payments.campspot.com/"
nginx_1    | 96.78.0.242 - - [20/Sep/2018:22:37:37 +0000] "GET /favicon.ico HTTP/1.1" 502 575 "http://staging.logs.payments.campspot.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/68.0.3440.106 Safari/537.36"
Here is my graylog.conf
is_master = true
password_secret = ************************
root_username = campspot
root_password_sha2 = ************************
root_email = tech@campspot.com
bin_dir = bin
data_dir = data
plugin_dir = plugin
elasticsearch_hosts = ************************
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = data/journal
mongodb_uri = mongodb://mongo/graylog
web_enabled = true
web_listen_uri = http://127.0.0.1:9000/
rest_listen_uri = http://127.0.0.1:9000/api/
rest_transport_uri = http://staging.logs.payments.campspot.com:9000/api/
This is my nginx.conf
events {
http {
  map $http_host $auth_type {
    default                     "off";
    logs.payments.campspot.com    "off";
  server {
    listen 80;
    return 301 https://$host$request_uri;
  server {
    listen 443 ssl;
    #auth_basic $auth_type;
    #auth_basic_user_file /etc/nginx/.htpasswd;
    server_name logs.payments.campspot.com;
    ssl_certificate /etc/letsencrypt/live/staging.logs.payments.campspot.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/staging.logs.payments.campspot.com/privkey.pem;
    location ~* / {
        proxy_set_header X-Graylog-Server-URL http://$server_name/api;
        proxy_pass       http://127.0.0.1:9000;
this is my docker-compose.yml
version: '3'
services:
  mongo:
    image: mongo:3
    volumes:
    - mongo_data:/data/db
  graylog:
    image: graylog/graylog:2.4
    volumes:
    - /etc/graylog/server:/usr/share/graylog/data/config # Mount local configuration directory into Docker container
    - /etc/graylog:/etc/graylog
    links:
    - mongo
    - nginx
    ports:
    - 9000:9000 # Graylog web interface and REST API
    - 514:514 # Syslog TCP
    - 514:514/udp # Syslog UDP
    - 12201:12201 # GELF TCP
    - 12201:12201/udp # GELF UDP
  nginx:
    image: nginx
    volumes:
    - /etc/nginx:/etc/nginx
    - /etc/letsencrypt:/etc/letsencrypt
    ports:
    - "80:80"
    - "443:443"
volumes:
  mongo_data:
    driver: local
  graylog_journal:
    driver: local
I can provide the full logs if they would be of help.
Heyo @Casey,
Your Graylog is only listening on it’s containers local loopback address 127.0.0.1. This is why it is not responding to requests on the IP 172.18.0.3.
You’ll have to alter the Graylog config for it to respond to 172.18.0.3 :slight_smile:
You might also want to consider to use Dockers internal DNS system where you can use the container name as hostname. So if your Graylog container has to be restarted and, for some reason, gets a different IP address, your system would still work and not run into the same issue again :slight_smile:
Greetings,
Philipp
your Graylog configuration is pointing to port 9000 while NGINX is running on 443
 server {
    listen 443 ssl;
Thank you @DerPhilipsi & @jan those changes helped me get a little bit further.
