Graylog Docker Failed to connect: Connection refused
I’m trying to run graylog in a docker container running on AWS. I’m able to get the web interface up and running and can login an create inputs, etc. However i am unable to actually send any logs to graylog. Nothing shows up in the stream or search. Further, testing from the command line i get the following:
(removed http headings for this post due to forum rules)
curl -XPOST X.X.X.X :12201/gelf -p0 -d '{"short_message":"Hello there", "host":"example", "facility":"test", "_foo":"bar"}'
curl: (7) Failed to connect to X.X.X.X port 12201: Connection refused
Even from inside the container i get the same message:
root@41c5489c3654 :/usr/share/graylog# curl -XPOST localhost :12201/gelf -p0 -d '{"short_message":"Hello there", "host":"example", "facility":"test", "_foo":"bar"}'
curl: (7) Failed to connect to localhost port 12201: Connection refused
If I run this same setup on my local laptop it seems to be able to recieve messages without issue.
My docker compose file looks like this:
version: '2'
services:
  mongodb:
    image: mongo:3
    volumes:
      - /Users/<redacted>/docekr/data/mongo:/data/db
  elasticsearch:
    image: docker.elastic /elasticsearch/elasticsearch:5.5.1
    volumes:
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
      - xpack.security.enabled=false
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 1g
  graylog:
    image: graylog2/server:latest
    volumes:
      - /Users/<redacted>/docekr/data/graylog:/usr/share/graylog/data/journal
    environment:
      - GRAYLOG_PASSWORD_SECRET=<redacted>
      - GRAYLOG_ROOT_PASSWORD_SHA2=<redacted>
      - GRAYLOG_WEB_ENDPOINT_URI=127.0.0.1:9000/api
    links:
      - mongodb:mongo
      - elasticsearch
    depends_on:
      - mongodb
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 514:514
      # Syslog UDP
      - 514:514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
      - 5555:5555
volumes:
  mongo_data:
    driver: local
  es_data:
    driver: local
  graylog_journal:
    driver: local
You can wrap text snippets in a code block to circumvent these rules and it will even look better!
See Markdown Reference for details.
What type of inputs have you created in Graylog and what’s the configuration of these inputs?
Hey Jochen, thanks for that info, i’ll def use that for next time.
For testing I created the following:
GELF HTTP
bind_address: 0.0.0.0
decompress_size_limit: 8388608
enable_cors: true
idle_writer_timeout: 60
max_chunk_size: 65536
override_source:
port: 12201
recv_buffer_size: 1048576
tcp_keepalive: false
tls_cert_file:
tls_client_auth: disabled
tls_client_auth_cert_file:
tls_enable: false
tls_key_file:
tls_key_password: ********
GELF UDP - port 12201
override_source:
port: 12201
recv_buffer_size: 262144
GELP TCP - port 12201
max_message_size: 2097152
override_source:
port: 12201
tls_cert_file:
tls_enable: false
tls_key_file:
use_null_delimiter: true
Syslog UDP - port 514
allow_override_date: true
expand_structured_data: false
force_rdns: false
override_source:
port: 514
store_full_message: false
Syslog TCP - port 514
force_rdns: false
override_source:
port: 514
tls_cert_file:
tls_enable: false
tls_key_file:
use_null_delimiter: false
Raw input - port 5555
override_source:
port: 5555
tls_cert_file:
tls_enable: false
tls_key_file:
The GELF HTTP and TCP were not both running at the same time. I created all of the inputs via the web console.
GELF HTTP and GELF TCP cannot use the same port, because both are TCP-based.
Try using a different port for one of the inputs.
Hey Jochen,
Thanks for the feedback, I think i got this working now. It looks like i had a typo in the docker-compose.yml. Thanks for your response and help!
