andrej
(Andrej Timofejev)
September 24, 2019, 10:10am
1
I’m trying to renew the enterprise license on Graylog rev 2.5.1 but process terminates with an error:
Could not retrieve license information
Verifying license failed with status: cannot POST http://x.x.x.x:9000/api/plugins/org.graylog.plugins.license/licenses/verify (400)
In previous post there was a solution to upgrade license plugin version from 2.4 to 2.5
https://community.graylog.org/t/graylog-2-5-2-renewal-license/10327
Please advice how to perform license plugin upgrade.
My current installed License Plugin is 2.4.6
Thank you.
marcod
(Marco Diomedi)
September 24, 2019, 11:33am
2
Hi Andrej,
I installed the graylog-enterprise-plugins-2.5.2 package wich contains the archive, auditlog and licence plugins.
Kind regards
Marco
andrej
(Andrej Timofejev)
September 24, 2019, 12:10pm
3
Marco,
thank you for a quick response.
Where did you got the graylog-enterprise-plugins-2.5.2 package from?
BR, Andrej
marcod
(Marco Diomedi)
September 24, 2019, 2:04pm
4
Andrej,
what graylog server version do you have installed? Check in System/Nodes
follow the instructions on this page, change the URL …/2.5/… in accordance with your version,
https://docs.graylog.org/en/2.5/pages/enterprise/setup.html
under “Tarball” for download and install the plugins.
Regards
Marco
jan
(Jan Doberstein)
September 24, 2019, 2:16pm
5
Server and Plugins need to be the same Version. Always.
If you have updated the Plugins to the same Version as the Server, you can enter the new license.
andrej
(Andrej Timofejev)
September 24, 2019, 2:46pm
6
Marco,
thank you very much, help is much appreciated.
Task completed with plugins downloaded from “Tarball”, my version is
2.5.1
After placing the plugins in /opt/graylog/plugins/ and reboot I was
able to activate the license.
I tried to update without success from cmd by command: apt-get
install graylog-enterprise-plugins
BR, Andrej
marcod
(Marco Diomedi)
September 24, 2019, 4:06pm
7
Andrej,
I’m glad to have helped you solve the problem.
Kind regards
Marco
