Fresh AWS AMI installation
Just spun up a new AWS AMI of Graylog.
but when i visit the url http://PublicIP:9000
i get this error
Error message
Request has been terminated
Possible causes: the network is offline, Origin is not allowed by Access-Control-Allow-Origin, the page is being unloaded, etc.
Original Request
GET http://PublicIP:9000/api/system/sessions
Status code
undefined
Full error message
Error: Request has been terminated
Regards
Kevin
  • Did you check the security Group?
  • Did you check if a Firewall is in between?
  • Can you reach your Browser the PUBLICIP on Port 9000?
Jan,
Thanks for your reply.
Yes i get to the login screen on my public ip :9000
But there’s a grey box that says its loading and then the above message.
I used the AWS AMI listed in your github repo.
I also ran the graylog-ctl setup public ip then reconfigure. But that didn’t solve it either.
I then also set the public up in the graylog.conf
But still no joy…
From what you describe, your Browser is not able to connect to the Graylog API.
As you use the AMI, can you please share your /etc/graylog/graylog-settings.json maybe we can spot something wrong on that. Or it is simple just some kind of security group that disallow the connection.
sorry for the delay, i was off on Annual Leave.
contents of /etc/graylog/graylog-settings.json
“timezone”: “Etc/UTC”,
“smtp_server”: “”,
“smtp_port”: 587,
“smtp_user”: “”,
“smtp_password”: “”,
“smtp_from_email”: null,
“smtp_web_url”: null,
“smtp_no_tls”: false,
“smtp_no_ssl”: false,
“master_node”: “127.0.0.1”,
“local_connect”: false,
“current_address”: “172.31.45.198”,
“last_address”: “172.31.45.198”,
“enforce_ssl”: false,
“journal_size”: 1,
“node_id”: false,
“internal_logging”: true,
“web_listen_uri”: false,
“web_endpoint_uri”: false,
“rest_listen_uri”: false,
“rest_transport_uri”: false,
“external_rest_uri”: “http://18.223.157.186:9000/api/”,
“custom_attributes”: {
& screen shot showing my security rules.
Regards
Kevin
He Kevin,
not sure about the issue - it might be related to your installation. Access to your API (the external Endpoint) is possible. But when using a Browser it runs into a timeout.
http GET http://18.223.157.186:9000/api/
HTTP/1.1 200 OK
Content-Length: 232
Content-Type: application/json
Date: Mon, 10 Sep 2018 14:03:58 GMT
X-Graylog-Node-ID: 6019884e-2532-485c-a77d-5a14f273bf97
X-Runtime-Microseconds: 2631
    "cluster_id": "ae3f3ac8-375d-4f08-9ce6-3f56c1d13efe",
    "node_id": "6019884e-2532-485c-a77d-5a14f273bf97",
    "tagline": "Manage your logs in the dark and have lasers going and make it look like you're from space!",
    "version": "2.4.6+ceaa7e4"
04
I guess that the system might be a little bit underpowered and does not answer in time. What can be found in your Graylog server.log? ( http://docs.graylog.org/en/2.4/pages/configuration/file_location.html#omnibus-package )
