Error bringing up imported graylog ova in virtualbox
I imported the graylog demo ova into my VB on Windows 7 and got this error when I tried to start the VM:
Failed to open a session for the virtual machine graylog-beta.
Details:
VT-x is disabled in the BIOS for all CPU modes (VERR_VMX_MSR_ALL_VMX_DISABLED).
Result Code:
E_FAIL (0x80004005)
Component:
ConsoleWrap
Interface:
IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
How do I fix this so I can run the demo to see if graylog is what we need for out logging?
Thanks.
Update:
It seems that part of the problem was that the VM memory was set to 4GB, which is all I have on the host. I scaled that down to 1788MB, and the VM booted, but all I get is a black screen.
Any clues or suggestions would be most welcome.
Thanks.
You have to activate the processor’s virtualization extensions (VT-x) in the BIOS of your computer:
Less than 4 GB of memory is problematic for the virtual appliance. While you can tune it to require less memory, with the default settings it’s only happy with 4 GB and more.
