Graylog (ubuntu-ova) 3.2 Vbox - ovb 5.1.8 - crash start
Hello
I did imported an ubuntu-graylog-3.3.2-1.ova on an Ora Virtual Box 5.1.18, running on a Windows 7 64bit machine.
It crashes on start. (can provide VBox.log and VBox.png)
On the same environment (Ora Virtual Box 5.1.18 - win 7 64) I can successfully start an ubuntu-graylog-2.5.0-1.ova - previously installed .
Is there any version problem with Ora VB 5.1.18 for ubuntu-graylog-3.3.2-1.ova?
first error I can see is:
00:00:02.182385 ERROR [COM]: aRC=VBOX_E_IPRT_ERROR (0x80bb0005) aIID={02326f63-bcb3-4481-96e0-30d1c2ee97f6} aComponent={DisplayWrap} aText={Could not take a screenshot (VERR_NOT_SUPPORTED)}, preserve=false aResultDetail=0
best regards
Your VirtualBox version 5.1.18 is really old (from 2017), try to upgrade to newer version.
https://www.virtualbox.org/wiki/Downloads
Also you use Windows 7, which is not supported anymore (EOL was in 14.1.2020):
https://support.microsoft.com/en-us/help/4057281/windows-7-support-ended-on-january-14-2020
Is there any doc which states that Graylog 3.2 dos NOT support Ora V Box 5.1.18? If yes upgrading would make sense.
More precisely. What version of Ora V Box does Graylog 3.2 support? this and the above I could not find in the docs
best regards
Altin
Graylog 3.2 OVA is based on Ubuntu 18.04 LTS (kernel 4.15)
Virtualbox officially support kernel 4.15 from version 5.1.34, see changelog:
https://www.virtualbox.org/wiki/Changelog-5.1
So upgrade at least to version 5.2 (or 6.0) which is still supported on Windows 7 (up-to this month)
https://www.virtualbox.org/wiki/Download_Old_Builds_5_2
Virtualbox 6.1 doesn’t support Windows 7:
https://docs.oracle.com/en/virtualization/virtualbox/6.1/user/hostossupport.html
