I downloaded the ova graylog2.2.1 and when I start the VM , I press ubuntu and then it get stuck into a black screen. I already activate virtualization in BIOS and tried different RAM memory and still gets stuck.
Yes, I was following that documentation when I came up with that error.
But I already found a solution. Using an older image.
I’m very new to Graylog. I’m also getting the same issue. I imported graylog-2.2.3-1 OVA file on my Virtualbox VirtualBox-5.1.20-114628-Win on my Win 7 OS laptop.
Please help me here.
Hello!
I solved my problem using an older version of the image. Version 2.2.2. Try
that. It might work.
That was what was happening to me.
What version did you install?
To be precise it’s - graylog-2.2.3-1
That is the latest version. The error appears in that version to me too.
Have you tried the version 2.2.2 ?
It worked for me.
Yet to try. Will definitely let you know.
