Hello dear community,
I just installed the version SonicWall Content Pack - GL 3 https://marketplace.graylog.org/addons/5aef3d25-4284-4e79-b364-6759d2db0c24
and configured the stream rule from msg must contain to message must contain VPN.
I have input from the UDP Syslog on the port: 12205 and after the configuration of one stream rule: massage must contain VPN. I´ve incomming Massages on the Stream.
But sadly, the dashboard does not work as desired, only the counters for successful and unsuccessful registrations work as intended. Any ideas where I could look after the problem. I would be really grateful for your help.
I am running GL 3.2 on Ubuntu 18.04 LTS and latest mentioned Elasticsearch and MongoDB Versions.
he @Nille
I guess that you might need to configure the sonicwall in a specific way?
Maybe you ask the author directly? https://github.com/spejosh/SonicWall3CP
