It seems not possible anymore to export a search to an already present dashboard, every time it creates a new dashboard and we can’t add searches to the same dashboard anymore in a new tab in a dashboard.
Second problem is when we duplicate a tab in a dashboard and change a working search, nothing is presented anymore, when we replay the search, data is shown, it looks like in the background the copied search is kept withing. The same happens when we duplicate a result within the same page.
What is even more strange is that if we remove the search from the duplicated dashboard the search from the TAB the data is copied from is shown.
Working TAB:
Search in working TAB:
Working search in a copied TAB shows no data in the dashboard;
Data is shown from previous search when the search is removed:
OS Information: Rocky linux 8.8
Package Version: Graylog 5.0.13 Operations
Forum and internet searches.
Testing it on Graylog Open 5.0.13 and the problem in duplicating
a tab within a dashboard is not present there.
Guideline on working with dashboards. This aint working as it was in 4.3.15
