Move widget between dashboard pages?
Hi
I’ve a Linux dashboard with page1 and page2.
When I create a widget since the search page, by default I could only select the Linux dashboard and Graylog put the widget to page 1 of the Linux dashboard.
If I want to create widget on page 2, I do this by the sidebar.
Is it possible to move a page 1 dasboard to page 2 on the same dashboard ?
Graylog 3.3 have option to copy widget from one page to another…
Hi
I use Graylog 3.3.2.
On the widget default page dashboard, actions available are:
  • edit
  • duplicate
  • delete
Since the search page, actions on widget are:
  • copy on dashboard > select dashboard > validate
Where you see it ?
Sorry my mistake, there is only option to duplicate page…
