Configure NTP with OVA
I’m using Graylog 2.4.6 on OVA.
I can change the NTP server on ntp.conf and it’s ok, but when i reload graylog with “graylog-ctl reconfigure”, original ntp.conf file is reloaded with default ntp servers.
There is a way to make ntp servers into “graylog-settings.json” or and other way ?
Thanks.
First important reminder is to ask whether you are using the Graylog OVA for anything beyond a simple PoC, or a quick test. Because, the OVA is not intended for production usage.
