How to configure graylog under reverse proxy?
Thank you very much.
Please refer to the documentation at http://docs.graylog.org/en/2.3/pages/configuration/web_interface.html#making-the-web-interface-work-with-load-balancers-proxies
Thanks for information.
Let me try.
If you’re using the OVA, you have to use graylog-ctl to change any settings. Manual changes to the Graylog configuration files will be overwritten when running graylog-ctl reconfigure.
I use graylog-ctl reconfigure but configure file not change. still default configure.
hej @cherawich
did you check the dokumentation for graylog-ctl?
http://docs.graylog.org/en/2.3/pages/configuration/graylog_ctl.html
